Page 31 of 41 FirstFirst ... 21272829303132333435 ... LastLast
Results 601 to 620 of 809
    #601
    Quote Originally Posted by doo View Post
    Pag Grid-tie system di magagamit sa gabi or whenever may power outage.
    Sent from my 2107113SG using Tsikot Forums mobile app
    Yes, kahit naka genset, hindi din nagagamit ang solar as source if brownout.
    Signature
    Mar 2004
    #602
    Ooops ... sorry wasn't clear ... thought the sentence was complete ...
    If you have NET metering and there's a power outage during the day, your solar panels are not allowed to deliver power since you are connected to the grid ... This is for safety of the power utility personnel that could be working on the grid near your house ...
    NET metering is when you are connected to your electric company and selling your excess power to them ... also note that you do not get full value of amount you are selling to your electric company ... for example, if you are paying 10 pesos / kwh ... the power you sell are not credited as 10 pesos, it's much lower than that ...
    #603
    You are correct. Net metering is pang sukli lang sayo for the excess electricity from your solar panels that you don’t use. Kesa naman masayang, e di gawin pera.
    Signature
    Meron ka na solar? Hinde ba mahirap mag pa install sa existing house? Yun iniisip ko parang ang daming gagawin yun mga wires paano ibabaon nanaman sa mga wall.
    #605
    Sa office ko ang solar. Sa bahay hindi pa, takot ako baka magka leak sa bubong. Observe ko muna etong sa office.
    Regarding wirings, malinis naman mag linya mga installers. Pwede naman gamitan ng moldings.
    Signature
    Ayaw ko nga ganun na nakalabas mga wires saka yan sa bubong nga pala bubutasan.
    Mar 2004
    #607
    They are used to installing solar panels to existing houses ... remember to factor-in cleaning charges every 2-3 years ... they charge per panel ...
    Jan 2016
    #608
    True ba na nakakatipid pag solar? Yan kasi ang selling point nila palagi. And the payback period of 5-6 years parang hindi rin realistic. Wala kasi nagpopost ng actual figures puro claims lang. And silent din sila sa maintenance costs. Parang based on the available infoi get, I can make a rough guess na at least 10 years ang payback and that is if you're lucky enough na walang masisira sa panahon na yan, whether due to parts failure or AON. Para siyang Starlink, it only makes sense kung nasa lugar ka na walang serbisyo.
    Pareho din pala tayo ng concern about potential leaks sa bubong. I'm sure the installers will not care to make sure na pulido ang kabit at walang leaks. May guarantee nga pero perwisyo rin ung pabalik balik sa bubong and ung frequent tapak ng tao contributes to the weakening of the roof itself.
    #609
    Mas mabilis ang ROI if you apply for net metering. Yung sa akin hindi pa active yung net metering, pero nakakabit na ang meter, so i-credit din lahat ng exported electricity ko pag pumasok na sa billing ang net metering.
    So far, naka tipid ako ng 40% sa electricity bill ko after nakabit ang solar. Pag mag start na ma-credit ang net metering, mas malaki mabawas sa bill ko.
    Signature
    So right now ang ginagamit mo whole day is solar na lang?
    #611
    Yes, basta nay araw. And over capacity din installed panels ko kaya during peak sunshine, pure solar energy gamit ko and may naeexport pa.
    Signature
    Jan 2016
    #612
    Na compute mo na kung kelan mo mababawi gastos mo?
    #613
    Without the rebates from net metering, abot 6yrs.
    Signature
    Jan 2016
    #614
    Bakit di magamit pag power outage? When you are using solar, naka off ang Meralco di ba?
    #615
    Support lang kasi ang solar sa meralco. Baka hindi kayanin ng solar ang load pag brownout, either masira yung inverter or mga appliances mo due to low voltage.
    Signature
    So bale sa umaga solar gamit at yun muna utilized basta meron araw then pag hapon to gabi na balik sa Meralco?
    #617
    Depende sa araw and sa capacity ng solar panels. Sabay solar and meralco, pero priority ang solar.
    Signature
    Jan 2016
    #618
    Pareho pala kami ng thinking ni Shadow, but hybrid pala ang set up, parang may voltage regulator, pag na sense na kapos, papasok si Meralco. But then kung may outage pwede kaya gamitin for as long as pasok sa voltage supply nya. Alam mo naman more or less kung ano ang kaya nya i-power up, so you make a conservative load lang, like 1 or 2 electric fans lang, or 1 aircon if you oversized your panels.
    Or baka konting kulimlim lang, voltage drop agad?
    #619
    Problema naman hindi mo alam kelan may outage. What if nag brownout while you’re at full load and medyo makulimlim.
    Hindi mag drop ang voltage if makulimlim, babagsak lang wattage available. Dyan na papasok meralco power.
    Signature
    Jan 2016
    #620
    Will it do immediate damage, hindi ba pwede mag reduce ng load once nag outage? Dumadaan pa rin ba sa panel so you can just flick the breakers off and then flick on pag na adjust mo na load [emoji28]
House Construction
