Page 29 of 41 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 809
    Mar 2004
    #561
    Can you share websites where we can get ideas for house designs? ...
    Nov 2017
    #562
    Check this youtube channel, they featured good house design.
    https://youtu.be/q8nHd-kRhc0
    Apr 2010
    #563
    Got some ideas from this channel and was able to build an A-frame farm house in the province.
    Rassel Catapang - YouTube
    Sent from my 2107113SG using Tsikot Forums mobile app
    Jan 2012
    #564
    Home - Kanto - Creative Corners
    BluPrint - The Definitive Authority for Architecture and Design in the Philippines and Southeast Asia
    Architecture from Philippines | ArchDaily
    Then theres Instagram, I particularly like *musebase_official, *wallflower_architects, *pitsou_kedem_architects, and many more
    But try to have one cohesive idea so your house wont look "chopsuey"
    Jan 2016
    #565
    Kung lay out marami different sites, kung interior design, I use Pinterest, pasok lang ng pasok ang designs sa feed.
    But don't worry too much about design, kasi kahit ma perfect mo yan, after 1 year, may makikita ka na "sana ganito ang ginawa ko" [emoji38]
    Mar 2004
    #566
    Thinking of open space ground floor indoor outdoor ... but how to deal with mosquitoes and bugs ... for security, maybe put roll up doors ... or maybe use big louver doors ... then there's the matter of dust ...
    Also thinking of just omitting the living room and have a home theater room in it's place ...
    Mar 2004
    #567
    Makes you wonder if there are no bugs in Malaysia ... or these people are somehow immune to mosquito bites ...
    https://www.youtube.com/watch?v=q8nHd-kRhc0&t=1s
    Mar 2004
    #568
    What is your ideal size for a home (floor area)? ... Will 50T / square meter allocation be good enough these days? ... How long does it normally take to build a house? ... Just give estimates ... Thank you ...
    Jan 2016
    #569
    My ideal minimum is 20 sqm each for bedrooms, sala, kitchen, dining and utility areas, 8 - 10 sqm for T&B, and 48 sqm for garage, 3 meters easement front and 2 meters for the other 3 sides and all of these in a bungalow set up. Bonus na lang kung may loft, so need to allocate for stairs also.
    As for budget, to give you an idea, a new construction in front of me costs 40/sqm, with no fence, gates and landscaping and probably a simple kitchen. So sakto ang 50k to complete everything including additional fixtures or upgraded finishing specs.
    For a 2 storey 200 sqm house 6 - 8 months is enough if the contractor has enough people.
    #570
    50T is on the high side na, although it depends din sa location ng house, and also the total area of the house to be built. The smaller the area, the higher the cost per sqm.
    Signature
    Mar 2004
    #571
    50T was high pre-covid? ... but now materials cost more? ... not sure ... used to be 25T-30T was minimum ...
    On another note ... how much do build and sell usually mark up? ...
    Jan 2016
    #572
    Mine was done at 25k pre COVID. My neighbor was quoted 30k after lockdown but was revised to 35k due to inflation, this is basic finish.
    #573
    Depende pa din sa location ng project.
    Labor in NCR is higher, also with gravel and sand.
    Signature
    Mar 2004
    #574
    Aren't materials more expensive the farther away from NCR you are ... additional shipping cost ...
    #575
    Depends on the material and where you’re located. Cements and wood come from the provinces. Shipping cost for other materials might be negligible. But with labor costing as much as 30-40% of the project, that is significant.
    Signature
    #576
    that's what happened to our house in the province, it's slightly more expensive than Manila.
    #577
    First time ko nakarinig ng ganyan.
    Unless yung workers lahat galing din ng Manila.
    Signature
    Nov 2017
    #578
    Mas cheaper pa din sa province nung nagpagawa ako ng vacation haus late 2020 to 2021, kumuha ako ng separate contractor for the whole roof trusses structure using thicker gauge roofing, significantly cheaper compare sa Manila.
    Solid narra door na custom size na height and width, 6 in total, sobrang mura compare sa Manila.
    #579
    No, province. I meant the materials
    Totoo ba ngayon na ang singil ng electrician per "butas" like outlet or switch? Papalitan kasi yung mga outlet/switch sa bahay namin sa province and he said P300 each e total of 31 yun We haven't had any electrical work done in our house in Manila e yung mga little things yung all around na namin gumagawa
    Jan 2016
    #580
    Yes, per butas but usually that price means he will lay down all the wires, pipes etc. as in full lay out ng electrical system ng under construction na bahay. Pag simple palit lang ng outlet or switch much much less because pwede palitan ang isa in 10 minutes or less. let's say na 15 minutes na, so 4 in 1 hour, in 8 hours, that's 32 outlets. No one's going to pay 9300 kesos for that hehe. I would give it to him for 1000 lahat na. That's generous na given na hindi kailangan electrician ang magpalit nyan. But still better to get an electrician just in case things pop up that only an electrician can solve right away.
House Construction
