Results 191 to 200 of 808
- Jan 2008
- 4,726
August 20th, 2020 11:17 AM #191
August 20th, 2020 02:05 PM #192
August 20th, 2020 02:11 PM #193
If it's possible to use a power sprayer on the wall, that would be sufficient to remove loose paint and debris, then you can apply plexibond 2 coats, which is ideal, while the surface is wet. Then 2 more coats Boysen Acrytex, that's what I did. As Shadow says, maintenance with Acrytex or similar paints.
Edit: plexibond on wet surface pala applies when it is bare pa, ask na lang the paint experts if this is also the case with painted surfaces.
August 20th, 2020 04:00 PM #194
August 20th, 2020 04:02 PM #195
August 20th, 2020 04:05 PM #196
August 20th, 2020 05:13 PM #197
August 20th, 2020 05:15 PM #198
Ang sama talaga ng itsura. Parang bodega.
August 20th, 2020 05:39 PM #199
August 20th, 2020 05:40 PM #200
Roadstar is reliable.
Finding the Best Tire for You
