Results 691 to 700 of 808
- 54,186
July 11th, 2023 01:57 AM #691
- Dec 2013
- 680
July 11th, 2023 04:31 AM #693
Yes!! Yan nga yung commercial. Is there a local equivalent of that product?
https://youtu.be/aXP3C5Kg-7w
- Dec 2013
- 680
July 11th, 2023 08:55 AM #694Quick check in shopee...i think sold locally naman yung product.
Sent from my CPH1937 using Tsikot Forums mobile app
July 11th, 2023 09:39 AM #695
The active ingredient of non repellent termiticide are usually filpronil or imidacloprid.
Marami nyan sa Lazada, like Termidor or Taurus SC, both filpronil. But I don't know if they come in foam spray form. Meron powder, which they use as bait. Same principle, lalakaran ng termites, at ita transmit sa kasama nila hanggang sa queen bee. Careful lang if you have pets.
Alphacypermethrin pala ang active ingredient ng Chaindrite, ginoogle ko. Permethrin ata commonly used insectide?
July 11th, 2023 02:58 PM #696
I keep a few cans of Bayer Premise(Imidacloprid 0.05%). Similar to the non-repellent Termidor. Pretty effective for resident indoor above-ground drywood termites. Just drill series of holes onto suspected areas of activity/infestation. Spray in the foam & patch it up w/ putty. It won't be instant, but they'll eventually be rid of. Avoid repellent termicides...they're not as effective as the non-repellent foam.
Sent from my SM-S901E using Tsikot Forums mobile app
July 11th, 2023 07:14 PM #697
Can it be put in a roll of tissue instead and covered with tape on the infected area? That's what the termite company did with one of our doorjambs. The reason being that the soft tissue is much preferred than the harder wood and indeed after 2 weeks it was already half consumed. So he placed another one, and again after 2 weeks, no bites. Means mission accomplished [emoji3]
July 11th, 2023 09:27 PM #698
Hehe...to get more miles out a can? Can they be sure the activity dint just move elsewhere? Hitting suspected areas at multiple points raises coverage & success rate. I initially experimented Premise & now try to keep a few cans handy. Easy effective DIY.
For prevention, we trench perimeter walls on all our recent builds....gives owners that option to DIY & save sums.
July 11th, 2023 10:08 PM #699
On a different note Sir Travs, is there a simple metric used to estimate cost of kitchen cabinets, countertop and built-in cabinets?
July 11th, 2023 11:05 PM #700
With the accessibility of everything you only used to see in luxury euro cabinetry, guesstimates are no longer that simple. Local customizers have come a long way, too. Carcass materials now have rot/borer-proof options. Drawers are more of integral load-bearing systems these days. Granite is more memorial park than kitchen material now. Cabinetry, usage, needs, tech & lifestyle have evolved so much....we have to constantly update.
I suggest to shop around, sir. Lotsa options & the cost range has widened significantly.
I do not have technical knowledge on cars. Since I am scouting for a new ride (I already have an...
BYD Sealion 6 DM-i
