Page 36 of 46 FirstFirst ... 26323334353637383940 ... LastLast
Results 351 to 360 of 451
    #351
    A lazy hour’s drive to Baguio via that route will do.
    No it will not. 1 hr 30 is more likely even for a fast driver. Roads are too tight to average 60 kph on the corners.
    This is a segment of the route with tight corners and varying elevation.
    I only recommend the road if Kennon is closed and Marcos is clogged. Otherwise it will take longer than the 2 other routes.
    #352
    offered ba ni Waze yan? Usually marcos and naguilian other options binibigay diba?
    #353
    Doesn't appear on Waze or Gmaps as an option. Which is probably why super konti dumadaan even if the traffic in Marcos is already bad.
    #354
    Copy bro. Will take your word, last option yung ruta na yan.
    Dec 2017
    #355
    If I may ask, how do you set it on Waze if it's not offered as an option?
    #356
    Parang wala unless sadyain mo tumbukin yung daan, ibabalik at ibabalik ka niya sa preferred niya na suggestions.
    Ayoko gawin baka maligaw ako mahirap na [emoji12]
    #357
    I manually add a stop in Google Maps (there's an option to choose a location on the map and drop a pin there):
    Nov 2017
    #358
    Try this on waze:
    1. Set BenCab Museum along Asin road as the destination point. Initially waze will give you the Aspiras-Palispis (Marcos) hwy route.
    2. Then search for Tubao-Asin road and add this as your stop in waze. This will give you the route to Tubao Asin road that will lead to Baguio. Once you reach BenCab museum, set your hotel destination.
    Try to do #2 on waze first so you'll find the Tubao-Asin road area from the map. This worked for me last year when I took this route.
    Nov 2017
    #359
    Dec 2017
    #360
    I'm used to it, getting lost while using Waze. As a matter of fact, I always bring an extra 20 liters of fuel for Justin Case.
    [emoji3]
    Try this on waze:
    Thank you!
Easiest way to go to baguio from manila
