Page 163 of 241 FirstFirst ... 63113153159160161162163164165166167173213 ... LastLast
Results 1,621 to 1,630 of 2403
    Quote Originally Posted by SpinCycle View Post
    If the only reason I had a bulge was the bad roads, then all my other tires should also have bulges.
    I’ve had enough of this conversation, you are obviously trolling my posts. Please find something better to do.
    ive seen my fair share of buldges..
    #1622
    Factory tire pressure recommendations factor in fuel efficiency besides load.
    There are good & bad tires.
    No Trolling sa Topic Tread..este Thread..
    Nakaka-dugo na kasi ang mga english replies..
    Pag nag-oblong/bukol ang gulong.. depende kung ano ang size ng mismong gulong, at saan ba talaga ginagamit yung certain vehicle..
    Kung Sedan, once na "gutter" lalo kung sharp yan.. mataas ang tendency na mag-oblong.. di lang gulong pati rin sa mags..
    AUV/MPV/SUV, once na nag-oblong/bukol ang gulong at mags... mas malaki ang diameter ng mags kaysa sa gulong..
    lol wrong spilling..
    Jun 2012
    #1624
    May mga bulok na tires talaga like nexen sa starex. 15k km pa lang, ang kapal pa, may bukol na. At kung magbabasa basa ka, prone talaga sa bukol ang nexen kahit sa ibang cars. So just accept it. Hindi sa usage yan
    ganyan talaga ang nexen. makapal pa bumububukol talaga. im sure maingat yun driver at non existent ang gutter. bulok ang nexen 🙃
    #1626
    Just because it hasnt happened.. doesnt mean it wont.
    Honda suggests 35F33R for the CTR and on the Civic Sport 235/40/18s
    Should we follow Honda?
    First, the recommended tire pressure isn't the only safe tire pressure you can use. Going +/- 3 PSI won't increase your chances of sidewall bulges. I've tried 35/33 and it rides stiffly on our roads. Also, the R18 is 70 kg lighter than the L15 turbo, so slightly lower tire pressure is fine.
    Second, even with properly inflated tires, you can get sidewall bulges. I had them on my Dunlop LM703 (205/55R16) that was always properly inflated.
    Sometimes, it's just bad tires. Sometimes, it's just bad roads. But it's never because of a small variance in tire pressure.
    Dec 2018
    #1627
    newbie here. what is the best tire so far in the market? planning to try a different brand for my sedan.
    #1628
    Quote Originally Posted by baker2005 View Post
    Better question is how much are you willing to spend for new tires. Tire prices depend on brand, model, and size.
    For those with 17" or bigger rims, the more upscale brands (Bridgestone, Michelin) will cost around 9k or more per tire.
    Dec 2018
    #1629
    tire size is 205/55r16. Im after its durability, okay lang kahit medyo pricey.
    #1630
    Common size eto ng compact cars. What do you have? Civic or Altis or Mazda3?
    You can check out Bridgestone Turanza GR series or Michelin Primacy series.
Low budget yet good quality tires
