Results 1,591 to 1,600 of 2394
November 26th, 2018 09:29 PM #1591
nitto nt830 225 50 17 98y
excellent value after discounts 😅
semi quiet, made in japan. grips corners really well. havent lost traction like some tires.
November 27th, 2018 12:54 PM #1592
Bro, since you have heavier loads I wouldn't recommend a cheaper tire. If the Bridgestones make it to TWI that means they are suitable for the job despite the load. 50TKm is pretty good already. Radials will always give you more mileage. This advantage is even greater when the unit is used in long haul trips. Bias tires overheat in these conditions and treadwear is accelerated as a result. If you want to try different radials I'd try Yokohamas. But I bet the Bridgestones will still outperform them.
The only time I would use bias tires is if:
1. The unit only does regional deliveries.
2. Overload is more than 20%
3. Unit is driven on bad roads or off road
4. No radial option
And even then I only use the more expensive ones (i.e. MRF). The Goodyears are still bias construction, that's why they don't last as long. Where are you located? The quote you got for the R200 is way too high.
November 27th, 2018 02:11 PM #1594
November 27th, 2018 02:37 PM #1595
Bridgestone R200
Front 58 psi
Rear 94 psi
"cold"
as per sticker on the chassis.
November 28th, 2018 12:09 AM #1597
Sharing this guide to convert tread in millimeters to qualitative/percentage descriptions:
Lagi kasi ako nakakakita ng for sale na tires lagi nalang 80% tread pa daw pero 3mm nalang natitira. 80% worn na pala.
December 1st, 2018 09:21 AM #1598
Actually, the bridgestone quote is from tirecenter.ph
Anyway I dont know why but the other day the canter experienced a blow out. Front tire this time (we experienced a rear tire blow out with another canter). I always tell the drivers not to underinflate (causes excess heat hence blowout). I checked last week and it was overinflated by 10 psi (so I just left it alone) . Is it possible an verloaded the cargo (2400Kg) [Payload is less than 2200 (2185kg?)] can cause the tire to blow? If its overloaded , the rear should have blown (bec heavier load and thinner remaining thread)
- 1
December 2nd, 2018 03:18 PM #1599
- Apr 2008
- 6,237
December 2nd, 2018 03:44 PM #1600
Traffic!
