The Advan series are sport tires. They offer better grip and handling over the BluEarth series but generally, sport tires have shorter life span.
I don’t think it will last 5 years specially if you do between 10k to 15k km per year. Maybe 3 years would do for a sport tire.
Magkaiba ang bakbak sa upod. If you're measuring kung ubos na tread ng tires mo, you should measure if pantay na yung tread sa treadwear indicator:
My old Fleva V701 lasted 40,000 km before needing replacmement.
You need to replace tires every 5-6 yrs, or if you hit your treadwear indicator.
Btw, the V701s aren't good sport tires at all. Less grip than my stock Hankook Ventus S1 Noble2 or my previous Kumho Ecsta LE Sport. Only Advan by name but no match to the real Advan V105 or AD08.
Meron dito - Achilles | Mindanao Tyrehaus
Wala pala 205/45/r17 si BluEarth.
Achilles 2233 good ba? dami rin reco sa viosclubphils FB group. Pwede kaya mag 205/50/r17 para bawas tagtag? using stock suspension.
Using Yokohama Advan Fleva 205/45R17 for my Mazda 3. Ok naman as a daily tire. Better wear than my previous Bridgestone Potenza RE003, pero malayo yung grip.
Achilles 2233 tires ko before for my Altis. Lasted me 42,000 km so roughly the same lifespan as the Advan Fleva. Mura ng 2233 though so if budget is a concern, this is a good choice.
Have recently replaced my 07 Santa Fe's Nankang Surpax SP5 fronts. Lasted 2 years and 4 months or 17448kms according to my records. Lasted about twice as long as the Westlakes that preceded it, but not particularly satisfactory either, though I have to say the grip is indeed very good while it lasted.
Now trying out Thunderer Ranger SUV 235/65/R17s which I got for 5k each.
Sent from my SM-G965N using Tapatalk
Anybody here used Saffiro tires? They are on sale now at Concept One.
Ano ang pinaka luma na for tire's date of manufacture na acceptable when buying new tires? Also another question if ever ba na mag palit ako from 185/55/R15 to 195/55/R15 for Ford Fiesta pwede ba yun?
Please i need your advise... i just recently discovered this on my tire... will this cause any problem or unsafe issue?
No need to replace yet?
4 scratches but not deep...i think ka level lang ng lettering sa tire yung natuklap...TIA!
I see! Okay I will look into those. Thank you
It's a 1997 civic. It was lowered by I would say... 2.5 - 3 inches.
Yes, it does the rubbing sound when i'm making a sharp turn.
It's been almost a month now I think since I lowered the car. I see no signs of damage on the tires so far so there's that at least.
