Results 1,611 to 1,620 of 2394
- Jan 2018
- 844
December 3rd, 2018 11:59 PM #1611
- Jan 2018
- 844
December 4th, 2018 12:05 AM #1613
December 4th, 2018 12:11 AM #1614
I use 32 for ALL the 18" tires I've ever used. No lumps whatsoever.
The ATR Sport is an awful tire and there's a lot of negative feedback on it - poor grip, poor durability, poor build quality. Which is why Achilles released the ATR Sport 2 soon after, because the ATR Sport was such a dud.
Even Mang Ben, owner of Ben's OK, adviced me to go for the cheaper 2233 even if he'd make more money with the more expensive ATR Sport because he's gotten bad feedback about it from customers.
Sent from my SM-G950F using TapatalkLast edited by jut703; December 4th, 2018 at 12:16 AM.
December 4th, 2018 12:34 AM #1615
Just because it hasnt happened.. doesnt mean it wont.
Honda suggests 35F33R for the CTR and on the Civic Sport 235/40/18s
Should we follow Honda?Last edited by StockEngine; December 4th, 2018 at 12:57 AM.
- Jan 2018
- 844
December 4th, 2018 12:39 AM #1616So there is no other reason the tire failed except for the 32 psi?
Can’t you accept that the ATR was a shitty product?
Also, my car isn’t a Honda. i followed my car’s tire pressure guidelines. Should I follow Honda even though I don’t have a CTR?
December 4th, 2018 01:01 AM #1617
32psi causing the bulge?.. its the weight of the car that compresses the side wall..so hard that the rim slices thru aome parts of the wall..
only reason you had a buldge is the bad roads.
December 4th, 2018 01:01 AM #1618
Semi OT:
Kung mahilig sa "Rubber-shoes"
Jordan man or lebron, at mas mataas or ibang brand na mas mataas pa ang halaga..
Why not to buy a "Priority" Budget, & "quality tires"
Basta ako.. di baleng gumastos ng gulong, once na kalbo na ang tread or talagang maraming nang nadaanan lalo sa construction area at road worthy, even sa highway driving at merong foreign object damage(s)
- Jan 2018
- 844
December 4th, 2018 01:11 AM #1619
December 4th, 2018 01:38 AM #1620
Factory tire pressure recommendations factor in fuel efficiency besides load.
There are good & bad tires.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
