naku di tanggal na warranty nyan kasi pinakalikot mo na sa 3rd partyGood day fellow Stafeyers! I-share ko lang po my experience regarding brake light problem.
Yesterday on two occasions muntik nakong banggain ng truck at kotse sa rear end. Umiiyak ang
gulong nila sa pag preno sabay businang galit pa pag nagbrake ako . Di ko pinansin. When I got home, I checked the lights kasi I always make it a point to check all external lights during the recommended 1-2 min turbo cool down period. Ayun! I discovered wala pala akong brake lights. Dead lahat Main brake lights, third brake light, pati rin yung dalawang brake lights sa bumper lights ko. All Dead! :shocked2: No warning light din sa dash to alert me about this problem. All tail park lights are working naman. Spent a couple hours checking all the fuses, bulbs and brake wiring no problem all in good shape. The owners manual was not much help kaya nag search ako sa internet until I came across some articles that pointed to the brake switch as the possible culprit. This morning I asked my driver to bring my SF to Hyundai Erod and they confirmed the problem. Its the brake switch that became faulty. This thing is found near the brake pedal arm. Its a moving contact switch kaya subject to wear and tear every time we step on the brake pedal. 15T km napo SF ko.
Papalitan daw nila ito coz under warranty however wala daw stock. OhTatawagan na lang daw ako pag meron na
Papano ngayon yan? This is serious stuff. How can I drive safely without brake lights?? I then asked my driver to bring it to Sir Benjie of Maspro sa Banawe. He dismantled the thing at kinalikot po niya. In about an hour ayos na brake lights ko! Thanks to Sir Benjie!
Did not even charge me a single centavo for it. Bumili na lang ako ng LED bulbs sa kanya as token of appreciation. We both know this is just temporary dahil remedyo lang and once I get the call from Hyundai for the replacement switch I will update you. Moral lesson: Always check your lights before kissing Fe good nite and in case of problems with Fe, dont hesitate to call our friend and idol - Sir Benjie. Drive Safely Po mga ka-SF!
