OT lang.
Pa byahe ako to Caticlan via Batangas Pier.
Okay na ba rfid sa star toll?
Sent from my SM-J730G using Tapatalk
Good day guys, i recently found out my 2015 CVX GS has leaking injectors because the sides of the injectors has fluid, although there seems to be no loss of power, i was thinking the seals are the culprit,....anyway anybody would recomemend which one is better, ishimoto or central diesel?
Sent from my SM-G965F using Tapatalk
As in basa ng diesel? Madami? Baka naman may maluwag lang na injector tubing nut at kaya mo na higpitan lang. There will be no loss of power as long as the pressure is still there. The injector will fail to deliver fuel to the cylinder only if the fuel pressure is loss, like when if the fuel line is loosely connected. Pag small leak lang from a fuel line nut that is very slightly loose di mo mapapansin lost of power.
I tried tightening the bolts and cleaned them to see if it will leak again in a few days, i couldnt send the pictures, it wont upload
i would have waited a while, for the engine to cool down.
sudden metal cooling isn't good.
I replaced the high pressure oil bypass hose and the return hose of our GS at 50kkm.... It was starting to show signs of oil leaking.
Also had the dialysis of the atf....
Nag overheat yung Starex namin the other day, hindi napansin ni misis yung temperature at pinilit iuuwi. Can you recommend good mechanics? Tumawag ako sa fronte initial phone guestimate 60k :-(
^^ define "overheat". Did it blow out steam? Or the gauge was just on high-high?
Ano daw gagawin? Change head gasket? Overhaul water pump? Radiator work? O baka naman palit fan lang? When my grx was ondoyed and it overheated later it was just the fan dying. And that thing blew steam. It is basically the same engine as in the present gs, only 33 hp lower.
Pinaandar after 2 days, iba na tunog parang may bakal na kumakalampag. Sa timog flyover naramdaman humina hatak kaya umuwi na kaagad sa bahay (fairview). Ayaw na humila pag dating dito at hindi na maakyat yung bangketa.
Baka hilahin ko next week sa fronte in banawe.
