Page 393 of 404 FirstFirst ... 293343383389390391392393394395396397403 ... LastLast
Results 7,841 to 7,860 of 8077
    #7841
    Quote Originally Posted by boogie18 View Post
    Thanks sir! Any recommended shop in the south sir that does all this? Appreciate it!
    Sent from my VTR-L29 using Tapatalk
    Just to add to yebo's list, have the caliper sliding pins cleaned and re-lubed with silicone brake grease.
    #7842
    You can also have the EGR, intake manifold checked. If they’re clean the previous owner most probably had it cleaned before.
    Aug 2012
    #7843
    Actually i scheduled cleaning for this weekend, dint know how to check if its clean or not. Not really familiar with these things. Hope the guys doesnt proceed if ita not necessary.
    #7844
    QC ako e dito din lang ako kay powertorc motors pag atf dialysis. All others kaya ng gas stations.
    Btw, part lahat yan ng 40k km pm. So review the pm records baka naman nagawa na nung 40k km service. But of course for your peace of mind di naman masamang gawin ulit lalo na malapit na din 60k km service ng gs mo.
    Aug 2012
    #7845
    You have a point sir, might as well have it done for peace of mind.
    Sir for below, what do i need to buy if i already have a mechanic to do it?
    2. Flush brakes
    4. Flush cooling system
    5. Change power steering oil
    For atf, needed talaga sir yung dialysis method?
    Thanks for your inputs sir, really appreciate it!
    #7846
    Drain and refill lang for atf at every 40k kms. Thats fine. Leave dialysis for ultra long atf changes.
    Aug 2012
    #7847
    Quote Originally Posted by istan View Post
    Thanks sir! Is Mag1 a good atf brand? If not, what do you recomend? Thanks!
    #7848
    Safe to say, atf, buy from casa or consult ur manual. Ok lang expensive fluid, long change intervals naman.
    And better safe than sorry.
    #7849
    Consult your manual what are the required fuids. Pero sa brake dot3 or dot4 lang yan. Higit 1 liter magagamit for proper flushing so bili ka 1 liter plus 250ml. Sa power steering same fluid as atf. 1 liter din magagamit dyan sa power steering. Yung coolant lang ang alam ko na may particular coolant type ang hyundai. Meron nyan sa olx o shopee.
    Sa transmission check the color. Pag dark redish brown na pa-dialysis mo. Pag red pa naman ok lang drain and fill.
    Apr 2012
    #7850
    Find zic sp4 sellers on fb. Yan gamit ng karamihan na kakilala ko na naka GS including me hehe
    Sent from my SM-J730G using Tapatalk
    #7851
    Only way to check the egr unfortunately is to dismantle and have a look.
    To satisfy my curiosity i checked under our GS last night. May DPF nga. Its approximately below the front passenger seat. Looks like a catalytic converter na pang gas engines.
    #7852
    Meron hyundai fs oil sa Lazada, Hyundai XTeer Diesel Ultra C3 5W-30 fully synthetic oil for P1950 for 6 liters or 7 liters + oil filter for P2670. That is only P325 per liter, very reasonable for a fs oem oil.
    https://s.lazada.com.ph/s.RC5m
    https://s.lazada.com.ph/s.RC5n
    Aug 2012
    #7853
    Nice, have you tried using this sir yebo? Was planning to use motul but this isnhalf the price!
    #7854
    Hindi pa, everest kasi ride ko until last November. Kakabili ko lang ng GS ulit so under warranty pa and using casa oil. My previous GS (2010 model) i sold in 2016 but i used Zik oil.
    Motul? May nagsabi dito sa tsikot na FAKE ang claims nyan bro.
    Aug 2012
    #7855
    I see, is that different pa from yung Zic X7 na oil? Or yun din gamit mo before bro?
    Oohhh cge cge, wag nalang mag Motul kasi grabe din mahal haha
    #7856
    Zic x7 din. Before that i was using Royal Purple kaso mahal.
    Aug 2012
    #7857
    Hi guys, do you know where i can get the third brake light sa spoiler changed? Thanks!
    #7858
    Pa share naman ng performance ng H7 OSRAM Nightbreaker Laser Next Gen?
    Im planning also to upgrade the low beam into Osram either Nightbreaker Ultimate or Laser Next Gen.
    It took a long time but last week I finally gathered the courage to use a pair of pliers to turn the damn bulb holders. Super tight talaga ang bulb holder ng facelifted unit headlights. So finally i was able to replace the stock low beam bulbs with the nightbreaker laser bulbs. And last wednesday and tonight i was able to test. Ibang-iba ang buga from the oem. Whiter, much brighter and definitely much farther throw. Kung sa dati nasa mga 60 meters lang yung maliwanag (i have 3m dark tints on the windshield) now i'd say about 100+ meters na. And i think it could go further if i adjust the aim. Medyo mababa kasi ang aiming ng low beams nito. In addition ok din ang cutoff nya, well defined and no apparent glare. Sulit yung P2000 na price.
    Apr 2012
    #7859
    Natukso ako palitan ko nga akin [emoji1787]
    Papunta pa naman ako market market na may blade store
    #7860
    Kung may makita ka na original na RAYBRIG 4300K mas maganda yun. I had that in my santa fe and it was the best halogen bulbs i've ever used. Definitely more than 150% more light and twice the distance than the oem halogens. Sadly i've been searching but could not find. I got them from Maspro in banawe but they don't have it anymore.
2008 Hyundai Starex (Gen. 4)
