good day, i have successfully replace the rear wiper of my GS with a wiper refill i bought at handyman for only php 140 only, just cut or pile one end of the wiper (made of hard plastic only) so that you can slide out the old blade.
Not certain where I read it now, but accordingly, the rear wiper of the Avanza is exactly the same as that of our beloved GS....
Pabuksan mo na lang bro...
Forgot to take note of it when I opened up my taillight assembly because of a loose bulb...
And our owner's manual is useless....
Byahe ako sa Pampanga sa Wednesday with full capacity, pero nag aalangan ako sa nakalagay na tire pressure sa manual na 51 rear. Di kaya delikado yun? Parang ang tigas na masyado nun
peanut bulb, p21 if my memory serves me right.
nakabili ako dati ng philips p21 for the reverse light, much brighter than the stock. pero di ko din kinabit kasi i modified my rear lights cluster. the signal lights (which are bigger) became the reverse lights and the reverse lights became the signal lights. I also put a 55 watt h4 bulb in the reverse lights. pag may naka-high beam sa likod ko sa stop light i put it on reversebalak ko nga lagyan ng switch para sa mga ogag na nakasunod sa nlex na naka-high beam.
*yebo
I recall your rewiring. Heheh! Walang kawala.
*cvt
Tnx. Medyo kulang nga sa info but at least english naman. Gray market guys get it in korean.
