Got the shipment from Lazada 2 days ago for power sockets. Installed 1 each on the C pillars. Di na magaagawan sa 2 meter usb cable mga chikiting pag long drive
Sorry can't post pic, something wrong with my tsikot. Basta dun siya sa C pillar, yung plastic moulding na between upper and lower, madaling tangalin may 4 lang na clips. Just peel off the rubber seal on the door then pull. Then you can use a circular saw/hole saw to cut the hole. Pwede din yung drill bit for door lock bolt pero need to make bigger. Then wire it up to the fuse box and connect with fuse tap.
