Results 3,931 to 3,940 of 8077
January 28th, 2013 10:29 AM #3932
January 28th, 2013 10:52 AM #3933
I was reading the old specs of our GS:
For TCi A/T: Gear Ratio : 1- 2.804; 2- 1.531; 3- 1.000; 4- 0.753; Reverse: 2.393; Final Gear Ratio: 3.909
For VGT A/T: Gear Ratio: 1- 3.730; 2- 3.308; 3- 1.519; 4- 1.000; 5- 0.840; Reverse: 2.740; Final Gear Ratio: 2.929
Sa rekta: - final ratio (input to wheel rev)
TCi- 2.943
VGT- 2.460
So, if everything is equal,- ideally,- tipid si VGT ng about 16%.
Further if both are running at 2000RPM and with the circumference of our 215/65 R17 tyres at 2.234meters, then the TCi ground speed would only be at 91KPH, while the VGT ground speed would be at 109KPH.... Sa gearing pa lang ito.... BTW, this checks with my experience on our TCi A/T
17.9K:cupid2:
January 28th, 2013 11:09 AM #3934
^add ko lang sir
VGT sa 2500 rpm 140kph, 2800 rpm 160 kph, 3200rpm 180kph. kahapon yan sa sctex, 7 passengers and a weekend of luggage
January 28th, 2013 11:26 AM #3935
January 28th, 2013 03:00 PM #3936
January 28th, 2013 03:14 PM #3937
Walandyo, bro.
Engineer ka,- siyempre may theoretical at actual....
Siyempre,- mas tama ang actual!!! hahaha!
Whew! 180KPH?.... L!ntek,- sa Autobanh lang ako naka-experience ng ganyan + more....Tumatakbo kami ng 220KPH+,- may nagflash pa sa likod para mag-overtake...
At one time, sa motorsiklo pa... Grabe ang kapit/yakap ko sa driver,- pareho pa kaming nakainom (at linsyak,- lalaki pa....)Hindi ko mismo nakita ang speed, pero sabi ng driver about 180KPH daw!!! Lahat ng santo natawag ko na....
17.9K:cupid2:
- Apr 2007
- 487
January 28th, 2013 11:51 PM #3939Yung TCI is hindi pa CRDI, right? So mas matulin pa yung 3rd gen na Starex pala.
- Apr 2012
- 3,469
January 29th, 2013 12:28 AM #3940Tanong lang, wala bang problema kahit naka 11k KMS na ako? haha
di pa ako ngppa 10K PMS, wala kasing time at naghahakot palipat ng bagong bahay.
Thread was made nung 2018 pa po sir.
