Page 138 of 217 FirstFirst ... 3888128134135136137138139140141142148188 ... LastLast
Results 2,741 to 2,760 of 4331
    Nov 2011
    #2741
    Quote Originally Posted by Jgab View Post
    Hello po. Planning to buy Civic 1.8E by July, ask ko lang po nagkaka ubusan padin po ba ng unit sa casa? O meron within a week lang na release na ang unit nila? Thanks
    If cash, just look for SAs and ask them. But never pay the reservation fee, this will give them the leverage.
    If bank PO, ask your bank rep, meron sila mga connection sa dealerships.
    Less than 1 week lang waiting time ko last Feb. (bank PO) and yung SA sabi swerte na din ako kase di na ko pumila. Pero ni-hold lang ung unit sakin for 3 days, dapat may ATD na, else forfeited.
    May 2018
    #2742
    Hi Sirs, patulong naman meron po kasing leak ung sa baba ng transmission ko, ask ko lng sna mgkano mgpagawa then replacement nrin ng camshaft at crankshaft ska oil seal plus labor for honda dimensions 2002,. yan kc sbi ng mekaniko baka transmission na, though nglagay na cia ng gasket sa llgayn ng langis ung plastic na itim dun binaba nia na un nlgyn ng gasket then ung sa left side nia ung silver transmission ata un dun meron pring leak. . slamat po sa mkakapagadvise
    Jan 2016
    #2743
    Two weeks ago nag inquire ako, may available unit na pero silver, yung ibang colors may pila daw, may discount din na 10k, just don't know if for cash or credit.
    #2744
    Quote Originally Posted by Dancivic View Post
    ..hirap namang basahin!
    anubang ginagamit ninyo, cellphone with 123 keyboard?
    May 2018
    #2745
    keyboard po! ano po ba di nio mabasa malinaw naman po unless di niyo consider yong text word.
    meron po kasi ko problem i dont know if transmission yong problema kasi meron pong leak, and advise po kasi ng mekaniko palitan daw po ng camshaft at crankshaft and oilseal po. gusto ko lang din po malaman magkano po replacement ng ganoon kasama labor para sa Honda civic dimension 2002 model po. . . .
    #2746
    Yes, text speak is not allowed in this forum.
    I don't understand why people still type with shortened characters and incorrect punctuation/capitalization in the age of full keyboards on smartphones.
    Mas madali basahin ang - "kailangan ko po ng tulong with my Honda Civic" kaysa sa "nid q p0 ng 2long wd my hnda civic"
    #2747
    i would look at my gaskets first.
    and before i replace my crankshaft (and camshaft?), i would consider and replace my oil seals first.
    for all we know, only the seals need replacement.
    if the seals start leaking soon after replacement, than that is when i shudder to consider replacing my crankshaft.
    it is not that difficult to look for the source of oil leak.
    one but needs a strong light source, and complete willingness to get one's clothes, back, hair and arms, oily-dirty.
    May 2018
    #2748
    Okay. Thanks . i'll be back to you soon Dr. d, i will check to my mechanics if he has done of replacing my oil seals, As i remember he did replace my gasket but i think only for Oil tank. pro iyong katabi nia sa right side kapag nkaharap ka sa bay sa baba transmission ata yun doon po meron tagas ng kaunti.
    Dec 2017
    #2749
    Call Toyosco - 8334807, 8334810, 8871838, 8450175 for original Honda Parts.
    Give them the model name and year and they'll be happy to give the prices over the phone.
    Ask your mechanic to give you the proper name of the parts - camshaft oil seal, crankshaft oil seal and rear crankshaft oil seal. More often than not, it's usually the "rear" crankshaft oil seal which causes the leak underneath the oil pan and towards your transmission. Labor can take 3-5 hours as they have to remove the exhaust pipe and everything else underneath. It's pretty extensive.
    When it comes to oil seals, always go for original, don't go budget meal, otherwise, you're going to have leaks again.
    Kindly note oil leaks can sometimes be difficult to diagnose. When you think you've already replaced it, there are going to be leaks somewhere else. So, you need to address that as well.
    Good luck.
    May 2018
    #2750
    honda has really stepped up and went back in the game
    May 2018
    #2751
    Quote Originally Posted by brushless View Post
    Good luck.
    okay, very much appreciated. as per my mechanics it is transmission oil seal. But maybe i'll diagnose my car first to specialist so he can decide what to do,. .because my mechanics right now he can't do transmission job. I'll look another one. . thanks. .
    May 2018
    #2752
    Quote Originally Posted by TheUninvited View Post
    Thanks boss. Ang bilis ng release! hehe. Anong color ung civic mo?
    Thank you sir! Planning to get the WOP color, sana meron agad :D nakaka inip mag hintay ng matagal haha!
    Nov 2011
    #2753
    Modern steel sakin. First choice was lunar silver.
    Very common yung modern steel, kahit Brio meron nito haha. Pero it grew on me eventually. Lalo na nung pinalitan ko ng RS mags, mas umangas. (in my opinion).
    It doesn't show swirls that much, although kahit bagong wax di sya ganun kakintab compared to other colors.
    WOP excellent choice too. Mas bagay sa Civic X yung lighter colors since kitang kita ang ***y body lines.
    May 2018
    #2754
    Hahaha! Good choice pa din po sa modern steel sir. Actually yan ang pinag pipilian ko at WOP
    Next week mag inquire na ako sa bank. Excited na ako hahaha. Thank you!
    May 2017
    #2755
    Maganda for me Ang modern steel compared with other grey colors. Pabago bago ng shade depending on light intensity and angle.
    May 2018
    #2756
    Mga Sirs, Normal lng ba na bago mo start ung sskayan eh nkailaw ung battery indicator, oil indicator, plus ung check engine? tpos kpg start mo na ung sskyan nawala na ung ilaw ng indicator?
    May 2018
    #2757
    Good luck.
    Hi brushless,
    Normal lng ba sa light indicator (battery,oil,engine) na naka on bako mo start ung ssakyan? kpg umaandar na mkina mawawala na ung lights indicator?
    Dec 2017
    #2758
    Hi brushless,
    That's prefectly normal. What is "not" normal is that it stays on even after starting.
    May 2018
    #2759
    Oh great! thanks. =)
    Nov 2011
    #2760
    Quote Originally Posted by Shutterbug View Post
    Yeah, parang may resemblance sa Machine Grey ng Mazda, which really looks good (and better) for me hehe.
All New 2016 Civic
