Results 731 to 740 of 5300
- 54,282
September 7th, 2017 10:58 PM #732
September 8th, 2017 01:22 AM #733
When water goes in the intake and into the cylinder, the piston can not compress the water. Water, unlike air, is incompressible... well... *almost* incompressible... you can compress water, but it takes thousands of pounds per square inch to compress it *slightly*. Google says the pressure at the deepest part of the ocean is 15,000 psi, and the water there is compressed by less than 5%
The inside of your engine only sees about 190-220 psi (well, in engines I know of) while squeezing air to 1/10th its original volume (10:1 compression ratio)
When water enters the engine, the moment your piston starts travelling up and the intake valves close, it is trying to squeeze water that requires thousands of psi to compress even the tiniest bit. Guess which gives way first?
It's never a good move to let it sit in water at all. If I had a vehicle surrounded by water I knew it could never successfully ford, I'd disconnect the battery, turn the ignition a few times to remove any remaining current in the system... pull the ECU if I possibly could... and run.
If it's a short distance, you could push it across and suffer very minimal damage, I guess... but it's no fun to try to wrestle a two ton brick that's floating on the water... and less fun when it fills up with water and becomes infinitely harder to push.
BANNED BANNED BANNED
- Sep 2015
- 13,917
September 9th, 2017 02:16 AM #734wala pa ako nakikita sa kalsada.....
hinahype lang talaga ito.....but wala talaga nagkakagusto...
- Jun 2012
- 87
September 9th, 2017 02:28 AM #735
September 9th, 2017 09:35 AM #736
Actually mahaba naka pila sa crv. It's like the civic sa sabi ng sales 2 to 3mos waiting time
Sent from my SM-A700FD using Tsikot Forums mobile app
- Feb 2013
- 927
September 9th, 2017 09:42 AM #737Hassle talaga mga trolls sa mga threads
- 54,282
September 9th, 2017 09:57 AM #738[QUOTE=niky;
.[/QUOTE]
i never thought of this... pulling out the ecu and leaving the rest of the car behind!
- Jul 2009
- 3,604
September 9th, 2017 10:19 AM #739
- Jul 2017
- 393
September 9th, 2017 01:05 PM #740http://www.topgear.com.ph/features/f...tition-fbfirst
Si sir niky :-)
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
