Page 353 of 359 FirstFirst ... 253303343349350351352353354355356357 ... LastLast
Results 7,041 to 7,060 of 7178
    Jun 2006
    #7041
    To rid of the priming issue, di ba pwede i-prime na lang lagi yung oil pump every change oil? Or masyado inconvenient to do so?
    Does it have some sort of nipple or cap of sorts so you can pour oil in? The idea is good but obviously their implementation is crap.
    Now, the Golden question, is the new Ranger/Everest also equipped with this stupid "feature"?
    Jun 2011
    #7042
    ️Sir hp... A better oil sensor would prevent further damage... Kung ma detect Lang ng oil sending unit... At Lalabas sa Dashboard yung warning na low oil pressure... Hindi na lalaki pa Ang problema at Sira...
    Jun 2008
    #7043
    Yes that's the one. Both the 3.2 and 2.2 have variable oil pumps.
    Sir sa t6 at t7 models ba to? Kc i have t7 3.2
    Jun 2008
    #7044
    Quote Originally Posted by Horsepower View Post
    Gusto ko rin malaman nga kung meron din ang new ranger nito?
    Jun 2011
    #7045
    Same engine Lang Yan... Fossil I don't think you have to worry about that... It's a mechanical failure and sensor failure... That can happen on all kinds of engines.l and brand--- Kaya nga din may lumabas na bulletin or advice to prevent this.. And ilan ranger na ba Ang nabenta? 30,000 ilan na ba ang may mangyari ang ganito? 2-3 units? Kung percentage Lang natin.. NASA .0001% .. Mas malaki pa ang chance na mamatay ka or mabanga ka at ma total wreck ang sasakyan mo..
    Dec 2008
    #7046
    "I rebuild these engines day in day out. ford for some reason have changed the oil pump from the ultra reliable gear pump to a sliding vane type pump, the ones where engine failure occurs is usually in pieces internally ,it seems that the sliding vanes in the pump simply break up and boom, no oil pressure. The problem isn't with ford, the oil pumps have been supplied by citroen/Peugeot as there are citroen and Peugeot logos on the casing but no fomoco label." - Ford Technician
    GOT THIS FROM FORD TRANSIT FORUM SO IT SEEMS KAHIT OK ANG OIL PRESSURE SENSOR IT WILL BE TOO LATE KASI BUMIGAY NA AGAD YUNG OIL PUMP.
    Dec 2008
    #7047
    First 4 PMS ko pa naman I requested the technician to drain the oil first and to wait 'til everything that has to be done was performed so the last thing he should do is pour engine oil and start the engine to check for possible leaks sa drain plug at oil filter. My last oil change was in my garage i let the oil drain for overnight para ma-drain mabuti, good thing walang nangyari but next time i won't do it again. Ang delikado yung may habit na gumamit ng solvent type na engine flush tapos papabugahan pa ng air dun sa oil filler cap para ma-force drain lahat ng oil kadalasan yan ang practice sa service center ng mga gasoline stations.
    Quote Originally Posted by Caracter View Post
    May mali talaga sa design nila nang turbo. Biruin mo karamihan patagalan patulo nang langis para malinis talaga engine kapag nag-o-oil change. Pero sa Ford na ito eh 30mins max lang dapat.
    May post si Yebo nung service advisory nang Ford/Mazda BT50 regarding dyan.
    Jun 2011
    #7049
    Kung bumigay ang oil pump.. Mag alarm dapat yun.. Ng low oil... Dba? Ayun nga ang purpose ng oil warning.. To warn us na low oil pressure or no oil.. Etc.. Tama po ba?
    Then syempre kung makita NATIn na may alarm.. Hindi na natin gagamitin.. Ma prevent ngayon ang any major or futher damage..
    Jun 2011
    #7050
    You mean overnight mo pinatulo?
    Kung ganun, mechanical failure ng oil pump Yung nangyayari sa iilan Naka ranger...
    Dec 2008
    #7051
    Ang problem is kung crusing speed ka kahit umilaw pa low pressure warning lamp eh nangyari na ang oil starvation dahil kung "sudden death" nangyari sa oil pump.
    Sabi ng friend ko sa Ford kaya daw nasisira yung bagong install na turbo replacement kasi plug & play ginawa nila hindi daw pala dapat ganun may tamang procedure pala hindi lang basta palit.
    Dec 2008
    #7052
    4pm to 11am to be exact naka-tanggal din oil filter...don't worry glenn siguro sa ginawa nating pag gamit sa ranger natin safe to say na walang problem ito now that we have reached 50K+ na mileage.
    Dec 2008
    #7053
    Biruin mo karamihan patagalan patulo nang langis para malinis talaga engine kapag nag-o-oil change. Pero sa Ford na ito eh 30mins max lang .
    Yes ang usual practice ko pa is i-suction yung remaining used oil sa drain plug using syringe with bent hose para masaid ng mabuti yung old oil.
    #7054
    One year ago Ford ranger talaga first choice ko sa pick up nice ride, looker talaga sya at macho macho ang dating kaya nagresearch ako at nagtanong tanong sa mga may ari nito mahirap talaga walang peace of mind at dealer support ang problema dito at yung mga mechanic nila di updated sa technology at servicing ng makina
    Jun 2011
    #7055
    Quote Originally Posted by piloski View Post
    Ganyan din AKO 2 years ago, kaya NGa ranger binile ko... Pero nung nagbasa basa ako dito, naniwala ako na pag Naka ranger ka Wala kang peace of mind.. Up to the extent that I even bought another bnew vehicle na there's no known major issue.. Worrh 1.8M--- then what I did, I drove my ranger Hard dinadala ko pa sa trail, na literal na tumatalon YuNg pickup sa mgA lubak... Rpm ko umaabot pa Nga ng redline, kinakargahan ko ng 1 ton load.. Then Derederecho sa lubak... I can feel that the suspension is sumasagad na.. Then no cool down... Gusto ko lumabas na Lahat ng problemA nya... Now after 50,000 kms. It still drives like Brandnew...
    You know what I regret in buying? The other vehicle...
    Question Lang-- Ilan tao ba nagpagtanugan mo? And do they really own a ford ranger? Baka naman Toyota o Mitsubishi sasakyan nila?
    Baka naman you are asking the wrong people?
    Punta ka ford ranger group,club or team... Then ask mo kung majority na sakanila satisfied o hindi
    Sep 2014
    #7056
    the shop in valey fair town center is Ilovekdm owned by mr gm bugayong. president of genesis club of the philippines. hes's the one who set up my genesis before. verry good shop and owner. madali kausap. [emoji106][emoji106][emoji106]
    Mar 2011
    #7057
    Quote Originally Posted by dcph172 View Post
    Yebo is this the one? I hope you can find a copy regarding the 2.2 as thats the one i have. This advisory just covers the 3.2. Why didn't they just say that its for both engine kasi? They share ba the same oil pump?
    Dapat pala parang F1 pit stop ang change oil nito. [emoji16]
    Quote Originally Posted by gundam View Post
    hahaha, parang ganun na nga. Lagay agad engine oil habang kinakabit new oil filter hehe . Joker ang Ford ah hehehe.
    I assume same system yan sa 2.2 engine. Sabay ginawa eh afaik.
    Jun 2011
    #7059
    Ewan ko ba? MgA u lol ata mga yan... Siguro verify muna NATIN mabuti ito kung totoo nga..
    Ngayon Lang ako nakarinig ng vane type na oil pump na 10mins. Lang change oil... Dapat dyan may ikabit pang self primming pump... Para ma change oil mabuti...
    Pero mine outside Casa na ako and others I know, 30 mins. Kung mag change oil..
    Si yebo may post, iba dyan yun. 30mins naman dun ang max time of patulo iirc. kaya siguro okay pa sayo. Kasi 30mins nga. So puwede pa. I'm sure hindi lang 30mins yan, pero sigurista na ford sa advisory for sure kaya ginawang 30mins.
2012 Ford Ranger
