Page 354 of 359 FirstFirst ... 254304344350351352353354355356357358 ... LastLast
Results 7,061 to 7,080 of 7178
    Jun 2011
    #7061
    Si yebo may post, iba dyan yun. 30mins naman dun ang max time of patulo iirc. kaya siguro okay pa sayo. Kasi 30mins nga. So puwede pa. I'm sure hindi lang 30mins yan, pero sigurista na ford sa advisory for sure kaya ginawang 30mins.
    Next oil change ko.. Naka off muna engine ng 30mins. Before I'll remove the oil drain... Para sure Lang mahirAp naman hindi sumunod sa Advisory...
    Better check pa din with the mechanic if okay yan. Baka kasi sa 40mins total eh bumaba na din oil sa oil pump mechanism. Baka sumablay pa din.
    Jun 2011
    #7063
    Yung 2.2 engine pala ng ranger is the same engine used by Land Rover Defender 2007-2011 model-- ang pinagkaiba Lang yung displacement 2.4 sa landrover 2.2 Lang sa ranger... It looks like iba ang engine model ng 3.2 sa 2.2
    Correct me if I'm wrong mga tsikoteers...
    Sep 2014
    #7064
    So luma na pala engine nyan 2011 pa
    Jun 2011
    #7065
    On a scale of 1 to 10, 10 being the highest, the puma engine was rated at 9.
    If the Land Rover Engine is old to your standards...
    Sep 2014
    #7066
    Year 2015 engine
    Jun 2011
    #7067
    Year 2015 engine
    Like what? Offered here in the phils. Ha sister....
    #7068
    engines take many many years to develop. baka akala ni OB parang fashion lang, nagpapalit by the season.
    Jun 2011
    #7069
    Nakalimutan ata Ni OB Na engine pinaguusapan, hindi Cellphone...
    Yearly dapat BAGO.. Ha.. Ha.. Ha..
    Sep 2014
    #7070
    Pinapapanallo na kita ngaujn coz I felt that you need this.
    Jun 2011
    #7071
    No sister... You're the real winner here at Tsikot...
    Agree..?
    Dec 2008
    #7072
    Share ko lang for those who have reached 30T kms to check on your brake pads, noticed ko kasi hindi even yung wear mas mabilis maubos yung outer pads sa front right wheel kaysa sa outer pads ng front left wheel.
    I interchanged them para maging even yung wear, now that it has reached 50T kms I checked it again malapit na mag-even yung wear but I also noticed that the inner pads for both front wheel ay mas matagal maubos kaysa sa outer pads. You might want to check your ranger for premature uneven wear so you can save on your brake pads.
    Surprised nga ako kasi usually sa automatic cars 30T kms due na for replacement ang mga brake pads kaya I checked it kasi palagi rin ako may heavy load pero so far ok pa. May nabasa rin ako sa foreign forum na abot ng 60T kms bago magpalit in my case kaya umabot kasi medyo malayo pa sa warning indicator na built in sa brake pads.
    Jun 2011
    #7073
    Quote Originally Posted by Caracter View Post
    Kamusta na pala ranger mo sir?
    Any problems encountered?
    Dec 2008
    #7074
    So Far wala na problem sir after mapalitan ng hose from intercooler, tapos had my oil change ulit yesterday using a timer para to follow yung 10 min drain time sa advisory, noticed ko lang na may tumutulo pa after 10 mins of draining pero binalik ko na rin yung drain plug just to be sure na di ma-totally drain yung vane type oil pump tapos mabilisang palit ng oil filter para masalinan ko agad ng fresh engine oil.
    Used it today so far drives like new again, binalik ko rin yung OEM na 17s set of tires mas comfortable talaga yung ride as compared to the 18s of the wildtrak. Super happy na naman ulit ako sa performance ng ranger hoping na wala ng lumabas na problem other than regular consumable parts.
    Manual tranny ba yung sayo sir? Kumusta yung performance ng shifting? I'm considering kasi to get yung facelifted na XLS 4x4 kasi 150 Hp at 375 nm na rin yung torque unlike yung dating 4x4 XL na 120HP lang.
    Jun 2011
    #7075
    Manual... Smooth shifting naman, Napancin Ko Lang Kahit 2nd gear, you need to fully depress the clutch for a smooth shifting... Yung mga magsasabi na nag gear hunting daw, Bopols Lang mag maneho mgA yun... Or baka na confuse Lang Sila sa reverse... Coz its positioned on the 1st gear, pero you need to pull the lever to engage it at reverse.
    Napancin ko sa dati kung driver, hindi nya matimpla NG maganda... Pero pag ako, kapatid ko at Anak ko nag ddrive... Hindi naman makadyot...
    Kung naka 50k kms. Ka Na, mukhang malapit na din palitAn turbo hose ko.... 50k na din kasi sakin...
    Dec 2008
    #7076
    Thanks sa info about driving a manual tranny, talagang nasa diskarte ng driver ang smooth transition in shifting between gears.
    Yung naging crack ng turbo hose ko sa may upper elbow yun daw at sa lower elbow ang common na defect ng turbo hose ng ranger, buti na lang nasira sakto bago nag-expire warranty.
    #7077
    Uh, gear hunting refers to ATs. 😊
    It's when the transmission lags because it can't decide between, say, second or third gear.
    Jun 2011
    #7078
    Uh, gear hunting refers to ATs. [emoji4]
    He he... Akala ko they are referring to manual tranny... May nagsabi kasi Dati, hirap daw cya sa pag kambyo... Sumasabit daw, mahirap timolahin, Sa loob loob ko, BOPOLS Lang cya magmaneho... Or baka nasanay Lang ako sa truck...
    #7079
    Mas madali pa nga for me yung clutch ng Ranger kaysa sa Altis. In general actually, mas forgiving lagi ang diesel na manual.
    Kahit bitawan mo ng biglaan ang clutch tapos walang gas, di ka mamamatayan because the torque can keep the engine from stalling. Sa gas mas precise dapat.
    That said, cars with electronic throttles have more throttle lag than their mechanical counterparts from 1 decade ago. Mas instantaneous ang response ng throttle dati so mas madali timplahin. But still, madali lang magadjust if you take the time to understand the car.
    Dec 2008
    #7080
    Really?...I must test drive a manual ranger, bakit kaya sa early pages marami nagko-complain na hirap talaga sila magtimpla at madalas namamatayan lalo na kapag hanging at traffic kahit daw matagal na silang nagdr-drive ng manual. Parang it takes time daw to learn yung start up from stand still or it's just them.
    Hindi kaya dapat sa 2nd gear na magumpisa kung walang load para smooth anyway malakas naman ang torque? Meron din kasi nagsasabi na very short lang ang 1st gear kaya mahirap sa stop and go traffic, ganun ba talaga?
2012 Ford Ranger
