Page 307 of 359 FirstFirst ... 207257297303304305306307308309310311317357 ... LastLast
Results 6,121 to 6,140 of 7178
    Oct 2004
    #6121
    Nag limp mode? Nagkaron din ba ng mild shift shock before it happened? How about the CEL umilaw din ba?
    Nangyari kasi sa akin may mild shift shock siya after 3500 km odo reading, i was observing kung lumala pa. Then while driving biglang umilaw ang powertrain warning lamp and it could only go up to 3rd gear. I tried turning the engine off and on saka umilaw ang CEL. Pag uwi ko ng bahay and reversing to park the vehicle ang lakas ng shift shock going from D to N and R. I tried all, P, R, N, D and grabe ang shift shock tumatagilid talaga ang pick up. Pero after maybe 5 minutes with the engine off (i got down to check the oil level and look around the engine and tranny for any obvious signs i can report later to the casa) i started the engine again and all the alarms were gone. I test drove it and all was ok. Idadala ko sana sa casa for a check up but meron ako lakad so i took the chance using it. Ok naman na siya, even went off road a bit, using 4H on the gravel and 4L on some mud, then sa hiway went up to 180kph (just to test). Nawala na din yung shift shock, smooth na shifting from P, R, N, D. So di ko na dinala sa casa for diagnostics. 3900km odo nya now.
    mazda bt50 3.2 a/t yung sa akin, same engine and tranny as wildtrak 3.2 a/t.
    Yes! Sakto!! Nag shift shock siya muna thrn eventually ito na the gears get stuck at 1st gear. I have to turn off the engine, and turn it on again para maging normal but nung huli ... Hindi na kinaya talagang limp na.. The shift shock happend to me months ago oa pero once lang then the 2nd time 2 mos ago? Then ito na yung 3rd instance with the shift shock eventually leading to the tranny failure.
    Called up Ford Libis, they still dont know the problem daw??
    Aug 2007
    #6122
    Sir pa basa nyo error para magkaroon tyo idea why.
    Free naman yan kasi warranty pa
    Oct 2004
    #6123
    Quote Originally Posted by erl919 View Post
    Actually nakailaw na yung powertrain light pero hindi parin nika malaman daw kung ano. Yeah buti warranty hassle lang hehe
    May 2004
    #6124
    cons of new technology to the market.
    Posted via Tsikot Mobile App
    #6125
    Palagay ko software issue e kasi nawawala pag off ang engine. Saka yung shift shock nya kung mechanical ang cause dapat di na sana nawala, kaso nawawala pag nag-off na din yung powertrain alarm. Hopefully it will be something that they can fix with a simple software update. Yun lang nga ang fix na yan will come from ford/mazda, not just from the casa.
    Aug 2007
    #6126
    Quote Originally Posted by niwde11 View Post
    Actually same din sa old cars. Auto transmission nagloloko din. The difference is now a days a light tells us something is wrong. Where as before no light.
    Like yung first starex namin 1mnt old nawawala drive pagmainit na. Tapos yung korean importer ayaw iwarranty-SAD
    #6127
    Ausie ranger and bt50 forums both report a possible miscommunication between the ecu and tcm, could be a loose connection or wrong signal. Some also reported a possible low voltage/electrical power issue that causes a fault in the tcm. Looks like we are not alone. Both 2.2 and 3.2 engines and both manual and automatic trannys suffer from this problem. Sa manual tranny syempre wala yung shift shock issue, limp mode lang na naka ilaw ang powertrain warning lamp and cel, and sometimes traction control. Now the problem is that in most (like in mine) the problem disappears when the engine is switched off and the ecu does not log the problem code. So if this happens we MUST all take a photo of the dash showing the warning lamps that are on. And maybe even record a movie that will show the shift shock happening.
    Jun 2011
    #6128
    Limp mode and shift shock happened to my focus.. The next day ok na.. So far months had passed hindi na nanaman bumalik...
    Sent from my C2305 using Tsikot Forums mobile app
    Oct 2004
    #6129
    I will drop by thr service tomorrow to get an update. It has been 2 days na pero no feedback yet. I think they should have had known the reason na agad since when i left the service nung saturday, the powertrain light is lighting up.
    Haaaay
    Aug 2011
    #6130
    Until now meron pa ba hinihingi D.I. Ang mga sales agent ng ford? As i recall last 2 years ago meron talaga d.i. ( ford alabang ) sila na ang pinakamababa noon at ang haba pa ng pila
    #6131
    Quote Originally Posted by kmo View Post
    Haaaay
    Ask mo kung aware sila na hindi lang sa unit mo nangyari yan, na madami na same cases sa australia and thailand rangers and bt50. Dapat meron na software update and ford/mazda since 2012 pa yung earliest case na nabasa ko.
    Oct 2004
    #6132
    Spoke to service yesterday, nag software update na sila so the powertrain light is not coming out. Problem, may jerking parin ... Sabi it might be mechanical na ...
    #6133
    I doubt kung mechanical. Sabihin mo sa kanila mine had severe shift shock, like as if the pick up was being bumped from one side but it disappeared after the powertrain warning disappeared. Most probably software lang, or wrong/missing signal between ecu and tcm (loose connection?)
    Aug 2010
    #6134
    Sana walang issue ang Manual ng 3.2L WT
    Top Gear Philippines | TopGear.com.ph
    Aug 2011
    #6135
    Sir anong model ng ranger to? Wildtrak or xlt? Matic or manual? TIA
    Oct 2004
    #6136
    Quote Originally Posted by Tj_abs View Post
    2.2 xlt matic sir. I just spoke to the brother of my friend. He has a 3.2 wildtrak same issue hehe he sold the vehicle na after hehe nawalan ng gana haha! Ummm well paran ganun narin nangyayari sakin
    Service called me up yesterday, "parang ayos na!" Parang??? I hope its fixed na ... Pero having thoughts on selling also
    Jun 2011
    #6137
    a/t tranny problem ng ford... nabasa ko na din dati yan...
    buti nalang nag manual ako...
    a/t lang ba ang may ganyan problema?
    Aug 2007
    #6138
    Mine is one month old palang so far wala problem. Sana updated version na yung akin
    Apr 2014
    #6139
    Same here mag 1 month pa lang wala pa din ako naramdaman problems..
    #6140
    Hehe, read aussie and thai forums, sama lahat manual and matic, 4x4 o 4x2, 3.2 and 2.2, ford ranger man o mazda bt50. Bwiset!
2012 Ford Ranger
