Page 122 of 195 FirstFirst ... 2272112118119120121122123124125126132172 ... LastLast
Results 2,421 to 2,440 of 3899
    Aug 2007
    #2421
    Doc. do you have LF3857 or LF3564 fleetguard filter. I will order some from you for my 4JG2!
    Dec 2007
    #2422
    I have plenty for the crosswind, and the lf3564 are on the way. You can look at my adds on sulit or justt send a pm to keep the thread on topic.
    May 2012
    #2423
    Sent PM doc! Thanks
    Aug 2007
    #2424
    Doc PM sent!!!
    Aug 2007
    #2425
    Double post
    #2426
    I hope we do not flood this thread by posting "pm sent"
    Jun 2007
    #2427
    thats a lot of filters doc! haha! LF3830 and BD7028 doc....please advice...
    Jan 2003
    #2428
    Currently using this Valvoline Blue 15w/40 that I ordered from a shop here in Baguio. Paid 3,300 for the pail containing 18 liters which is good for two change oils on my 4M41 Strada. Is this Valvoline Blue oil better than Delo 400? Delo is readily available compared to the Valvoline Blue that took one month to arrive after placing the order. Valvoline Blue is cheaper than the Delo 400.
    Dec 2007
    #2429
    They are about the same the only thing that matters is they both carry the Cummings rating
    Dec 2007
    #2430
    They both carry the same ratings so the will be for extended oil change intervals, the big C on the bottle is a winner everytime. Ace sells this for 199p a liter.
    Dec 2007
    #2431
    It has the cummins rating so its good to go.
    Jan 2003
    #2432
    I'll stick with the Valvoline Premium Blue oil then. Thanks, doc .
    Quote Originally Posted by G01 View Post
    Delo 400 is better but the price difference and the fact that you don't change oil more than 10,000kms mean that you're current oil is sufficient to provide all the protection you need.
    #2434
    sir, just wondering, how do you pour the oil? mejo hassle yata sa pail.
    Jan 2003
    #2435
    The lid has a small opening that is covered with a threaded cap.
    #2436
    what filter do you use? baldwin?
    May 2005
    #2437
    Quote Originally Posted by Ry_Tower
    Based on specs alone, DELO 400 is looking better.
    VALVOLINE ALL FLEET PREMIUM
    Performance levels / Approvals
    API CI-4/SL
    ACEA 04- E2/B3/A2
    ACEA 02- E2
    MB 228.1/ MB228.3 / MB 229.1
    Mack EO-M Premium Plus
    Volvo VDS 3
    Caterpillar ECF-1
    ZF TE-ML 07C/04C, Allison C4
    MAN 271
    Cummins CES 20071/ 20076 / 20078
    Typical Characteristics
    Appearance Bright & Clear
    SAE Grade 15W40
    Kinematic Viscosity, cSt * 100oC 14.91
    Viscosity Index 135
    TBN, mg KOH/g 9.5
    Flash Point, COC, oC 210
    Pour Point, oC, Max. -30
    CCS * -20 oC, cP, Max. 6700
    http://www.valvolineasia.com/Upload/...et_Premium.pdf
    Delo 400 Multigrade
    PERFORMANCE CHARACTERISTICS
    • API Cl-4 PLUS, Cl-4, CH-4
    • API SL, SJ
    • ACEA E7-08, E5-02, E3-96.
    • JASO DH-1
    • EMA Global DHD-1
    • Caterpillar ECF-2, ECF-1-a
    • Cummins CES 20078, 20077
    • DDC 93K214
    • Mack EO-N Premium Plus 03
    • Mercedes-Benz 228.3
    • Volvo VDS-3
    Planned Approvals
    • MAN M 3275
    • ZF TE-ML 04C, 07C
    • MTU Category 1 and 2
    • Renault RLD-2
    Meets the Requirements of
    • API CG-4, CF-4, CF, CD
    • Cummins CES 20076, 20072
    • Mack EO-M Plus, EO-M
    KEY PROPERTIES
    SAE Grade: 15W-40
    Density at 15°C, kg/L - 0.886
    Base No., D2896, mg KOH/g - 12.2
    Base No., D4739, mg KOH/g - 10.0
    Sulfated Ash, %m - 1.4
    Flash Point °C - 230
    Pour Point °C (-33)
    Viscosity, cSt at 40°C - 125
    Viscosity, cst at 100°C - 15.1
    Viscosity Index - 125
    Zinc, %m - 0.15
    http://www.caltex.com.au/productsand...n.aspx?ID=1639
    #2438
    i just had my oil changed this morning using delo 400 from previous petron trekker, so far less vibration and noise pa lang nararamdaman ko, will keep monitoring
    Delo Gold Ultra (which really good as well) kasi katapat niyang Valvoline all fleet premium. But at P183.33 nga kasi pail yung binibili niya, mas mura siya ng mga P20-30.00
    Dec 2007
    #2440
    You might want to check with berrimma diessel for some of my fine filters soon, sorry no 4m40 filters in stock yet.
Remote bypass oil filtration
