Page 119 of 195 FirstFirst ... 1969109115116117118119120121122123129169 ... LastLast
Results 2,361 to 2,380 of 3899
    Dec 2009
    #2361
    after 6 months of use on a ford everest gen1 in our province, this how the custom fleetguard looks...
    there are a lot of sediments and water on the clear bowl at the bottom
    there are also a lot of rust and brown like dirt of the pleats of the filter media and on the outer portion of the filter housing
    when it was still new and unused...
    the gasoline stations at our province are really down right dirty.. their storage tanks are full of dirt and rust... imagine the dirt that could potentially pass through and go to your engine...
    Apr 2012
    #2362
    I will let u guys know how much i have and what i have when they get here.
    okay sir dvldoc, just let us know when the filters are available...thanks!
    May 2012
    #2363
    Was looking at the cross reference site of JS Filters: JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C313J. For the Montero 2.5L, the fleetguard equivalent is LF3830. But based on back reading, the LF3564 is more commonly mention here. Question is, will the diameter/height fit?
    #2364
    Nakakaiyak.... :blue:
    laging hinahanap kung saan saan at ng kung sino-sino(volmax)
    nasa harap at dinadaan daanan lang pala ang hinahanap....
    the last piece daw at sakto sa change oil ko...
    Bwahahaha
    #2365
    swerte ni bg, nakabili nung bd28 sa 2nd-3rd avenue, last piece.
    Quote Originally Posted by miko101130 View Post
    Yup, better fill-up in PPC as much as possible. I believe that due to multiple transportation of fuel kaya nakakakuha ng ganyang contaminants.
    Got myself a BD28 c/o mateomarco. TY sir.
    May I make a suggestion sir.
    Limit the purchase to at least 2 pcs so that others may also benefit from a very good filter. With extended drain capability, afaik most people would need the most 2-3 per year lang naman di ba. After all, bosch is readily available for those who just want to hoard.
    Oct 2004
    #2368
    Doc, is it safe to run ZIC UP 10w-40 upto 10,000 kms on a Mitsubishi Triton/Strada 4d56 engine?
    Currently using the Asian-made Fleetguard LF3564 and it seems to be doing a good job at 4,200 kms (oil being very dark brown and not grainy to the touch). The oil actually wipes clean from the fingers with just a pass from a tissue paper and is still very fluid despite the dark color.
    #2369
    Bg, magkano kuha mo sa bd28? Swerte mo hehe
    #2370
    P840 cb, mas mahal yata compared ke volmax, pero ayus lang di naman ako pinahirapan mag park at sa trapik... hehehe
    #2371
    At pinaka important may stock hehe
    Dec 2007
    #2372
    Mga sirs, where can I get BT223 other than Volmax and how much? Tamad na ko magbackread. TIA.
    Dec 2007
    #2373
    By the way, I got all my filters in except for the 4M40 ones of course, You'll see them in the classifieds soon, I have to sort them all and put them up, it's like 600 plus of them,
    #2374
    Quote Originally Posted by timo07 View Post
    215each sa volmax
    Dec 2007
    #2375
    215each sa volmax
    Thanks, dalawang filter na pala equivalent ng orig.
    #2376
    just went to volmax. still no stock of bd28 hehe august pa daw.
    #2377
    august? what year?
    #2378
    hao siao na yan, last may, june daw, i went there last june, july daw, now july na, august naman......
    sa totoo lang, volmax should thank the starter of this thread because when the news of the bd28 exploded in this forum, volmax quickly ran out. they didnt expect the volume of people buying the bd28, since it is for mitsubishi 4m40 and 4m41 lang, filters like the bt223, practically all toyotas including the fortuner use this.
    #2379
    Quote Originally Posted by zix888 View Post
    august? what year?
    forgot to ask that one. i'll ask next time haha!
    Jan 2012
    #2380
    Mga boss alam ko medyo out of topic ako. Pero kasi napansin ko parang umingay lalo engine ng MS ko after my 1k PMS eh i used mineral oil galing sa casa. Pati oem oil filter. Then i fill my gas sa seaoil. I was wondering may kinalaman kaya ito sa langis na ginamit? Balak ko sa 5k pms ko eh sa labas na mga service center ko na pagawa para makapili ako magandang oil and filter.
Remote bypass oil filtration
