Page 116 of 195 FirstFirst ... 1666106112113114115116117118119120126166 ... LastLast
Results 2,301 to 2,320 of 3899
    #2301
    ^ wow, ang linis pa ng filter mo, seems like 15,000kms is easily achievable!
    How's the oil? Sandy feeling or still smooth to the fingers when touched and grinded together?
    yup ang linis pa talaga, nanghihinayang nga ako eh, even the oil is really very smooth pa when you grind it with your fingers. sa 12k solve na rin, magnotes na lang ako to keep track of my oil change
    ^ use the toilet paper testing also pati yung dumi sa fingers mo if may maiiwan kapag binbad mo sa used engine oil. If none, then filtration is really good. Sa bosch ginawa ko yan after 5,000kms, very good pa din. Next is 7,500 sa Bosch kung okay pa.
    Topped up about 200ml of fresh oil after 1,500kms though.
    Dec 2007
    #2303
    Baldwins do make some great filters.
    #2304
    guys.. may bd28 na?:D hehe.
    Jun 2007
    #2305
    I was about to say yeaaah! until I saw the question mark....
    ^ hahaha, ako din eh.
    #2307
    hehe wala parin? sino kaya dito satin naghohoard? hehehe jk
    Dec 2007
    #2308
    Good video on oil filter efficiency ratings.
    May 2005
    #2309
    Better Filtration = Smaller Pore Size
    Take one of the following precautions when you increase filtration:
    -increase surface area
    -increase porosity
    -decrease viscosity
    -slow down flow rate
    "increase the surface area" - does this mean on a very efficient filter getting the biggest size filter that can fit the vehicle?
    #2310
    Quote Originally Posted by AC View Post
    Magkaaminan na? :D
    Basta ako, wala akong Mitsubishi na diesel kaya malinis ang konsensya ko. :innocent:
    #2311
    Magkaaminan na? :D
    hehe next time BT223 naman yung mauubos
    #2312
    Shhh... diba yung BT233 pang Suzuki Alto lang yan? :tounge2:
    Jan 2008
    #2313
    ay wag naman sana!
    May 2005
    #2314
    So I take it meron na BD28? Tumatahimik na lang yung may alam? :D
    I guess I will call Volmax again. Na iirita na yung sumasagot. :D
    ^ wala pa ata eh? Balitaan niyo naman ako. Paubos na bosch ko. hehehe
  16. #2316
    Pati BF7534 wala nung last time na pumunta ako. Hoarded by the full monty?
    #2317
    Baka magkaroon ng voice prompt na yung Volmax: "If you are looking for BD28, please press plunger..."
    Oct 2004
    #2318
    Quote Originally Posted by doy View Post
    Sir, I will check visually the oil color and viscosity after 5,000 kms.
    http://tsikot.com/forums/strada-club.../index147.html
    So far it's doing a very good job compared to the OEM oil filter.
    Update after 4,000 kms:
    http://i6.photobucket.com/albums/y209/doy/Photo0784.jpg
    Oil color looks deep black in the picture but it's actually just very dark brown. Visually, oil was still smooth with no traces of metal on a white tissue paper and not grainy to the touch. Still using the Asian-made Fleetguard LF 3564.
    #2319
    The last time I went to volmax, wala part akong sinasabi, sinabihan agad ako na wala pang stocks yung bd28 hehe
    Rt, pano yung tissue paper test? I might change my zic up + bd28 combo on the 8k km.
    May 2005
    #2320
    Just sharing, this is what I installed last week during an oil change. I opt to use this instead of BT223 since there was ample space anyway. Fort gas.
    Matched it with Mobil 1 0W-40 European formula.
Remote bypass oil filtration
