Page 99 of 195 FirstFirst ... 49899596979899100101102103109149 ... LastLast
Results 1,961 to 1,980 of 3899
    Oct 2011
    #1961
    Sir cb, may available bang ZIC sa recto benavides area?
    or maybe no one buys it. were you able to ask for the price?
    currently enjoying Zic UP 10w40. cheaper than Top1 and mas lively yung engine.
    They said that they don't have the price for it, most probably no one knows and buys it. hehe
    Okay pala yang Zic UP sa'yo.
    Dec 2007
    #1963
    Quote Originally Posted by somar View Post
    Dvldoc, is it safe to say that with my current oil + filter combo ( DELO GOLD 15-40w CH4 + Luberfiner oil filter) I could extend my change oil interval to 10,000 kms ? without sacrificing good engine protection and lubrication? (everyday normal traffic driving)...
    Sir, yes its possible to accommodate another 2 to 3 inches longer filter as the engine bay (dmax) for the oil filter has lots of space. Am also sourcing out longer filters out there..
    You would be wasting money if your not doing at least 12000klm, That's just a 8000 mile oil change interval, not exactly pushing the limits.
    You should look into the LF3487, It's full microglass and would give you a easy 15000klm between oil changes not to mention is 73% efficient at 10 microns. Or you can stick with the Luberfiner and get the PH8A going to a bigger filter extends oil change intervals as well.
    Nov 2007
    #1964
    wow!
    EVEN if i only use CH4 rated 15-40w oil?
    Aug 2010
    #1965
    where can i buy zic oil in manila?
    how much does zic 5000 power cost?
    Dec 2007
    #1966
    wow!
    CH4 oil is killer oil, we wish we could still find the stuff, I has a ton of ZDDP in it. It was the bench mark when it came out, Oils have gone down hill since then due to emission requirements and low sulfur diesel fuels.
    Here is a nice little oil study to show you how well it works. CH4 oil was designed for extended drain intervals as well the later API rated oils for diesel. It's all about the TBN.
    http://www.engine-expo.com/05engine_...y1/dangare.pdf
    Oct 2011
    #1967
    Sir dvldoc, hindi pala maganda ang API CH-4 rated na oil in general for diesel engine? this is something new.
    ^ Mali ata pagkakaintindi mo? CH-4 is very good oil but CI-4 is great.
    Dec 2009
    #1969
    Guys this should generally be your rule of thumb when choosing the oil you need so that you get the most protection!!!
    **Amount of Sulfur in Philippine Diesel fuel >500PPM?
    **Is vehicle equipped with Diesel particulate filter?
    ----if sulfur level in fuel is greater than >500PPM choose CI-4
    ----if sulfur level in fuel is less than <50PPM choose CJ-4
    ----if vehicle is equipped with Diesel particulate filter use CJ-4
    ----if vehicle is not equipped with Diesel particulate filter use CI-4
    The main reason why CJ-4 is created is because in other countries
    Sulfur levels in the fuel have been reduced(advancement in diesel fuel)
    And prolong life of particulate filters and catalytic converters
    The TBN ( total base number/ ability to neutralize the acids formed primarily because of high sulfur levels in fuel) is lowered
    the CJ-4 oils have lower phosphorus and other anti-wear additives generally termed as ASH...
    The lower TBN of CJ-4 oils is due to the fact that the fuel has low sulfur and doesn't not need that much acid combating power
    The TBN of CI-4 oils are usually high (10-12) because the fuel that is expected to be used is high in Sulfur.. therefore it contains lots of anti-wear like phosphorus and others to combat the sulfur acid effect....
    As with our current sulfur levels in our diesel fuel CI-4 oils would be a better option...
    ONCE it has been legalized and less than 50PPm of sulfur is enacted then CJ-4 would be option,,,,
    (Am i correct DOc as to what i stated hehe,)
    Dec 2007
    #1970
    Your pretty spot on, all of those will have a high TBN of at least 10 and a proper level of ZDDP and a pretty high and will give you good protection.
    If you pick a oil try to pull their spec sheet, we have posted dozens and dozens of them on here to help you make your choice or just do a google search.
    Delo gold is a example of a oil that will serve you very well the TBN is 9.5 more than enough for a 12000km oil change interval.
    http://www.lubricantsonline.co.za/up...ulti%20CH4.pdf
    It also has 1500ppm zinc in it so that serious friction protection.
    Oct 2011
    #1971
    That is very informative sir. Nagulat nga ako sa description ng CJ-4 na dapat ay below 50ppm lang. Now, how about ung mga previous versions of API ratings like CH-4, CF-4 and CF? which is still available and common to our market.
    Oct 2011
    #1972
    my bad, mali nga pagkaintindi ko. i stand corrected.
    May 2009
    #1973
    how about CI-4 plus vs. CJ-4? i've read somewhere (some pdf file on the net) that CI-4 was tested (manufactured) under time constraints and so so thus the CI-4 plus.
    Dec 2007
    #1974
    All are good oils, unless your doing extended drain intervals and your using at least CH-4, CI-4, CI-4 plus, CJ-4 oils you will be fine, Though old school diesels should not really use CJ-4 oils many are below the 1200ppm for ZDDP.
    Always check the spec sheet.
    I made some comparison of diesel oils popular here. HTH in your quest of the ideal oil for you. Prices are based here in my place so it will vary.
    Some are also made to order like Gulf oils na direct sa national distributor and per case dapat order. Cheap per liter but expensive as a whole.
    #1976
    walang price yung Gulf hehe Top1 SDO pala has a high TBN.
    Dec 2007
    #1977
    I guess you can't get the Fleetforce 10w40 over the counter? Who sells it.
    hehe, miko sell it per liter, that is the cheaper option than buying in bulk. It is really for fleet options. I don't think its over the counter stuff.
    GULF OIL Philippines, Inc
    (An ISO 9001 & ISO 14001 Certified Company)
    39 M Lozada St. Brgy. Sto Rosario, Silangan
    Pateros, Metro Manila
    Dec 2009
    #1979
    most diesels engines in the street still needs lots of ZDDP...... although there are some improvements in the Philippines with regard to diesel technology still the same engines are used... plus the sulfur levels in the fuel are still high... If you adhere to emission standards but it makes your engine less efficient over time and more prone to breakdowns what's the logic of having emissions only to scrap your engine in less than 10 years....
    any CI-4 oils will really be good, basta paired with good filters!! and no extended drain intervals on city driving conditions......
    actaully and liit lang nang percentage nang driving population ang bagbabasa dito sa forums, baka less than 1% lang.... so the other 99% eh nasa dilim pa din at old school myths pa rin ang pinaniniwalaan....
    May 2009
    #1980
    Para sa lahat na may alam na info sa tanong na ito: saan ba yung mga oil testing centers dito sa luzon? pakipost na lang office names, addresses, contact nos., etc. dito sa thread na ito kung maaari.
    Tsaka ilan ml of oil ba ang kelangan isubmit for testing?
    TIA
Remote bypass oil filtration
