Results 1 to 20 of 3899
Threaded View
    Dec 2007
    All are good oils, unless your doing extended drain intervals and your using at least CH-4, CI-4, CI-4 plus, CJ-4 oils you will be fine, Though old school diesels should not really use CJ-4 oils many are below the 1200ppm for ZDDP.
    Always check the spec sheet.
Remote bypass oil filtration
