wow!
EVEN if i only use CH4 rated 15-40w oil?
You would be wasting money if your not doing at least 12000klm, That's just a 8000 mile oil change interval, not exactly pushing the limits.
You should look into the LF3487, It's full microglass and would give you a easy 15000klm between oil changes not to mention is 73% efficient at 10 microns. Or you can stick with the Luberfiner and get the PH8A going to a bigger filter extends oil change intervals as well.
