Results 1,891 to 1,900 of 3899
April 28th, 2012 04:26 AM #1891
Well when shipping from overseas there can always be delays.
But as far as the WIX goes, on this particular filter, yes they have a cross match that would work but the nominal rating is 30 microns which is not very good. The Baldwin is 12 microns. Normally WIX filters are very good but not for this particular application because.
But this does not put them out of the picture, If you can find the 51675 it's 19 microns nominal, It is slightly larger than the BD28 equivilant. I know some 4M40's and 4D56's have that Aircon hose that can block a larger filter so you will have to check if you have clearance.
51675
Height: 5.981
Outer Diameter Top: 4.282
BD28
O.D.: 3 11/16 (93.7)
Length: 5 3/8 (136.5)
If you do have the extra space you can also go with the BD7028.
April 28th, 2012 06:24 AM #1892
Tsikot Member Rank 1
- Jul 2009
- 4,090
April 28th, 2012 06:58 AM #1893Goodluck on wix, went to superior motors last january and ordered filters for 4d56, they said they are going to call me when my order arrives, well, upto now, nothing. Forced me to get a case of bd28 from u.s, price is higher than that of volmax, but i know i am going to have them, rather than just wait for volmax stocks
April 28th, 2012 08:14 AM #1894
- Nov 2007
- 50
- Apr 2012
- 9
April 28th, 2012 08:55 AM #1896
April 28th, 2012 09:47 AM #1897
It seems like it is a case to case basis. Some OEM filters have good fuel filters but bad oil filters and vice versa.
April 28th, 2012 01:17 PM #1898
Looks like I'll have to search for a Baldwin dealer here or in Davao. Fleetguard for oil and Baldwin for fuel. OEM fuel filter here cost Php 2,500+ which almost 3 times the price of Fleetguard FF5160.
April 28th, 2012 02:33 PM #1899
You can thank the disaster in Japan for many of the high cost of the OEM items. Lots of those factories were damaged.
If you know anyone in the state you can get Donaldsons for that filter for pretty cheap.
P502158 - FC1704 - FUEL FLTR<BR>DONALDSON REPLACEMENT FOR<BR>SAKURA PART# FC1704 - Filter Products
April 28th, 2012 03:17 PM #1900
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
