Results 941 to 950 of 3899
January 8th, 2012 07:25 PM #941
January 8th, 2012 07:28 PM #942
The square can style or round style will normally have a baffle in them. The purpose of the catch can is to separate the oil mist from the air and this is best done by slowing the flow so it settles out. If what you find is not baffled the best material to put inside for maximum effectiveness is fine grit steel wool, your other good options are a steel scrubbing pad, or foam. These all work great for getting the job done and are cheap.
January 8th, 2012 08:03 PM #943
The 1FZ-FE will take a Baldwin B2 filter. And your 100 series fits a Baldwin B228 filter but if you have a extra 3 inches of space i would use the long version which is the B178 it will give you longer filter life with the added media surface. You'll just have to check to see if you can fit that with nothing touching the filter and still be able to access it with a filter wrench to remove or replace.
Bosch in the states is different from there so the numbers will probably be different but it would be a 72161 for the 100 series and for your 80 series would be a 3510.
Your going to have to stick with OEM or other local brands for the fuel filters, if you want a Baldwin. Wix does have some though, the WIX 33526 for the 100 series and WIX 33563 for your 80 series. But frankly Toyota makes good fuel filters. If your in the Metro Manila area there is a WIX dealer it's posted on this thread but I don't know what page.
Tsikot Member Rank 1
- Jul 2009
- 4,090
January 8th, 2012 11:35 PM #945
sa ebay taiwan ko nahanap sir. around 1800 pesos kuha ko kasama shipping. Greddy copy lang siya hehe was looking for brand-less/generic kaso ang hirap maghanap hehe dito naman sa atin, hirap maghanap ng may 15mm na fitting. pag smaller fitting kasi baka mag back pressure yung OCC, which will cause oil leaks. i have an extra set if you're interested hehe
January 9th, 2012 11:12 AM #947
a friend did a DIY oil catch can in his patrol. after a few weeks, leaks started to come out everywhere. they were able to trace the problem to the oil catch can. the fittings were smaller than the fittings in his valve cover. kaya there was back pressure.
after removing the DIY OCC, the leak stopped. kaya careful in installing OCC. should be a little smaller than stock lang. cant be too small.
January 9th, 2012 12:39 PM #948
One thing you check prior to installing one that you can blow through it with little to no effort then you should not have a problem.
January 9th, 2012 12:51 PM #949
And on your friends rig if it's the ZD30 engine he needed to live the little restrictor in place. (edit feature of forum does not appear to be working)
Anyways, here the piece. But if you can blow through your OIL catch can it should never cause a problem.
- Jul 2009
- 4,090
January 9th, 2012 03:07 PM #950Doc i went to superior motors today and asked for a wix oil filter for my 4d56. They crossed my oem filter and what came up is 57092, which is different from what i found out online which is 51067. I just ordered because they dont have any stocks for any of those. I just told them to carefully check which will match my oem oil filter and make that order for me. They are going to let me know if its already available. I was just curious if both are the same maybe just the length is different
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
