Quote Originally Posted by paj4x4 View Post
Very informative thread dvldoc. I've shifted to Bosch from Vic oil filters for my Gen2.5 Pajero Fieldmaster (4m40). Would you know of the Bosh, Baldwin, or Purolator oil filter equivalent for the 1FZ-FE engine (80 Series Landcruiser) and the 2UZ-FE engine (100 Series Landcruiser)? I currently use Toyota OEM oil filters on these rigs. Thanks.
The 1FZ-FE will take a Baldwin B2 filter. And your 100 series fits a Baldwin B228 filter but if you have a extra 3 inches of space i would use the long version which is the B178 it will give you longer filter life with the added media surface. You'll just have to check to see if you can fit that with nothing touching the filter and still be able to access it with a filter wrench to remove or replace.
Bosch in the states is different from there so the numbers will probably be different but it would be a 72161 for the 100 series and for your 80 series would be a 3510.
Your going to have to stick with OEM or other local brands for the fuel filters, if you want a Baldwin. Wix does have some though, the WIX 33526 for the 100 series and WIX 33563 for your 80 series. But frankly Toyota makes good fuel filters. If your in the Metro Manila area there is a WIX dealer it's posted on this thread but I don't know what page.
