Page 95 of 390 FirstFirst ... 4585919293949596979899105145195 ... LastLast
Results 941 to 950 of 3899
    #941
    Quote Originally Posted by zix888 View Post
    Bro papost nung cusco occ mo, thanks
    i was able to find an OCC for my FM na sa wakas haha with 15mm fittings
    Dec 2007
    #942
    Quote Originally Posted by tuazon7 View Post
    Hi Doc, got a Cusco OCC but have'nt put it in yet. Need to still have the appropriate fittings/hoses/clamps to do so. But just noticed that there seems to be nothing inside it, though just managed to peek on the holes only. Browse the web out of curiosity and seems that most of the known branded OCCs have nothing inside or un-baffled, as they term it. Is this effective, some say yes others say no? Contemplating on having it opened and put some perforated sheet between the two nipples? TIA.
    The square can style or round style will normally have a baffle in them. The purpose of the catch can is to separate the oil mist from the air and this is best done by slowing the flow so it settles out. If what you find is not baffled the best material to put inside for maximum effectiveness is fine grit steel wool, your other good options are a steel scrubbing pad, or foam. These all work great for getting the job done and are cheap.
    Dec 2007
    #943
    Quote Originally Posted by paj4x4 View Post
    Very informative thread dvldoc. I've shifted to Bosch from Vic oil filters for my Gen2.5 Pajero Fieldmaster (4m40). Would you know of the Bosh, Baldwin, or Purolator oil filter equivalent for the 1FZ-FE engine (80 Series Landcruiser) and the 2UZ-FE engine (100 Series Landcruiser)? I currently use Toyota OEM oil filters on these rigs. Thanks.
    The 1FZ-FE will take a Baldwin B2 filter. And your 100 series fits a Baldwin B228 filter but if you have a extra 3 inches of space i would use the long version which is the B178 it will give you longer filter life with the added media surface. You'll just have to check to see if you can fit that with nothing touching the filter and still be able to access it with a filter wrench to remove or replace.
    Bosch in the states is different from there so the numbers will probably be different but it would be a 72161 for the 100 series and for your 80 series would be a 3510.
    Your going to have to stick with OEM or other local brands for the fuel filters, if you want a Baldwin. Wix does have some though, the WIX 33526 for the 100 series and WIX 33563 for your 80 series. But frankly Toyota makes good fuel filters. If your in the Metro Manila area there is a WIX dealer it's posted on this thread but I don't know what page.
    #944
    Bro san ka kumuha? How much?
    #945
    sa ebay taiwan ko nahanap sir. around 1800 pesos kuha ko kasama shipping. Greddy copy lang siya hehe was looking for brand-less/generic kaso ang hirap maghanap hehe dito naman sa atin, hirap maghanap ng may 15mm na fitting. pag smaller fitting kasi baka mag back pressure yung OCC, which will cause oil leaks. i have an extra set if you're interested hehe
    #946
    Oo nga, maliit yung fittings nung Cusco sa MOA eh.
    #947
    a friend did a DIY oil catch can in his patrol. after a few weeks, leaks started to come out everywhere. they were able to trace the problem to the oil catch can. the fittings were smaller than the fittings in his valve cover. kaya there was back pressure.
    after removing the DIY OCC, the leak stopped. kaya careful in installing OCC. should be a little smaller than stock lang. cant be too small.
    Dec 2007
    #948
    One thing you check prior to installing one that you can blow through it with little to no effort then you should not have a problem.
    Dec 2007
    #949
    And on your friends rig if it's the ZD30 engine he needed to live the little restrictor in place. (edit feature of forum does not appear to be working)
    Anyways, here the piece. But if you can blow through your OIL catch can it should never cause a problem.
    #950
    Doc i went to superior motors today and asked for a wix oil filter for my 4d56. They crossed my oem filter and what came up is 57092, which is different from what i found out online which is 51067. I just ordered because they dont have any stocks for any of those. I just told them to carefully check which will match my oem oil filter and make that order for me. They are going to let me know if its already available. I was just curious if both are the same maybe just the length is different
Remote bypass oil filtration
