Ok nga yang Mobil 1 TDT, P440 lang sa Cash & Carry sa Makati eh. Taas pa ng additive package at mas mura sa RP. Group ng oil regarding synthetics can be found here sir zix888 Synthetic oil - Wikipedia, the free encyclopedia
Fasten your seatbelt! Or else...Driven To Thrill!
Are there other dealers of Baldwin filters besides Volmax sobrang layo kasi from Cainta?
Found this place online KPS POWER they carry the following.
Fleetguard, Baldwin and Donaldson. Of course the normal inspection of non counterfeit inspection applies. Maybe someone can let us know how there Fleetguard and Baldwin stock is.
kpspower*yahoo.com
5533151
861 6209
+63-917-869-5002
They are also on facebook.
I also found a Authorized Donaldson dealer. They also carry fleetguard.
PRUDENTIAL INTERTRADE PHIL.,INC.
3276 East Service Road,
Bicutan,
Paranaque City
Also Donaldson
GV Masco Industrial Corp.
363 M. Vicente Street
Mandaluyong
1550
MOTO Industrial Traders Corporation
City Land Condo.10 Tower II Suite 1907 cor. Ayala/
H.V de la Costa St., Salcedo Village
Makati City
1227
Propmech Corporation
MTC Building
A. Soriano corner Arzobispo Sts., Intramuros
Manila
-Manila, PH (02) 285.98.80-96
-Subic, PH (047) 252.35.11
-Cebu, PH (032) 344.07.38
-Bacolod, PH (034) 433.49.10
-Zamboanga, PH (062) 993.19.05
-General Santos, PH (083) 552.55.04
dvldoc, what can you say about valvoline 15w40 CF-4?.....i've found out that a CF4 is the better one if not the best to use for a turbocharged diesel.
i think i'm having another problem with my bosch fuel filter....engine jerks/shudders when accelerator is released suddenly from high rpm......there was this one time the fuel gage was below Empty and i filled it up with 50 ml 2T and while travelling to the gas station (10 km away), tried to overtake and engine shut off suddenly....something like someone reached for the key and turned it off then on again. suspected it was air that entered the fuel system (due to below E on the gage)....trouble showed up again i think 3-5 times even with the tank full. problem occurs when engine is revved suddenly or in constant high rpm. does not show on cruising speed...what's your suspicion sirs? could a soft hose coming from the tank to the filter-separator assy be the cause?
CF-4 has a robust additive package, higher lubrication than current oils, That API rating has been obsolete since 2008 so if it has a API star on it that oil is 3 to 4 years old already. Still safe to use but i would not use any oil that is more than 5 years old there simply because the higher the temp the oil is stored the more oxidation you will get in the oil.
But if it was stored inside a store it's good for about 10 years.
the highest API rated oil i encountered so far is the new DELO gold multigrade semi synth. CI-4 afaik....my suking auto parts dealer told me its the chevron delo 400 in the US. but i still prefer the mineral multigrade of Delo. Delo sport synth i saw one at a servitek dealer too with CJ4/SM rating iirc.
Opps ment CI-4 not CJ-4 on my last post.
But here is a good read on CI-4 vs CJ-4
Side by Side: CJ-4 vs. CI-4/CI-4 PLUS oil | Equipment World | Construction Equipment, News and Information | Heavy Construction Equipment
Hi Doc, for the OCC on the Monty 4D56, will connect this to the breather hose? No PCV on the 4D56? thanks again.
Yes it connects to between the breather hose and intake hose. Diesels don't have PVC valves.
