Page 46 of 195 FirstFirst ... 364243444546474849505696146 ... LastLast
Results 901 to 920 of 3899
    Dec 2007
    #901
    Quote Originally Posted by freeloader View Post
    Does Baldwin BF7534 fit the 4D56?
    It fit the 4D56 and 4M40 all models.
    Quote Originally Posted by zix888 View Post
    Gusto ko sana fully synthetic. Yung mobil 1 TDT okay din daw base sa thread na ito. What do you mean by group 4? Thanks bro
    Ok nga yang Mobil 1 TDT, P440 lang sa Cash & Carry sa Makati eh. Taas pa ng additive package at mas mura sa RP. Group ng oil regarding synthetics can be found here sir zix888 Synthetic oil - Wikipedia, the free encyclopedia
    #903
    Thank you sir Ry_Tower
    Jan 2011
    #904
    Well if you find a real LF3564 let everyone know were you got it, remember no country of origin it's a fake. The LF3564 is also now being made in Argentina as well. Mobil1 TD has a much better additive package over RP.
    In a Turbo diesel it's all about the oil with the most Zinc, Phosp, Moly and Boron and Calcium and who has the highest TBN, all will give you longer oil life.
    Mobil1 0-40
    Royal Purple 0-40
    thanks Doc! Will check Mobil 1 TDT next time considering also na this is cheaper than RP.
    Jan 2011
    #905
    Bro how much per liter ng rp? Fully synthetic?
    Bro, 600 sa speedyfix at 640 sa philshopping. Fully synthetic. Will try Mobil 1 TDT next.
    Feb 2007
    #906
    Are there other dealers of Baldwin filters besides Volmax sobrang layo kasi from Cainta?
    #907
    Quote Originally Posted by tuazon7 View Post
    Okay thanks for the info. Try ko din muna yung mobil 1 TDT
    #908
    Try to call volmax and i quire if they have sub dealers.
    Dec 2007
    #909
    Found this place online KPS POWER they carry the following.
    Fleetguard, Baldwin and Donaldson. Of course the normal inspection of non counterfeit inspection applies. Maybe someone can let us know how there Fleetguard and Baldwin stock is.
    kpspower*yahoo.com
    5533151
    861 6209
    +63-917-869-5002
    They are also on facebook.
    I also found a Authorized Donaldson dealer. They also carry fleetguard.
    PRUDENTIAL INTERTRADE PHIL.,INC.
    3276 East Service Road,
    Bicutan,
    Paranaque City
    Also Donaldson
    GV Masco Industrial Corp.
    363 M. Vicente Street
    Mandaluyong
    1550
    MOTO Industrial Traders Corporation
    City Land Condo.10 Tower II Suite 1907 cor. Ayala/
    H.V de la Costa St., Salcedo Village
    Makati City
    1227
    Propmech Corporation
    MTC Building
    A. Soriano corner Arzobispo Sts., Intramuros
    Manila
    -Manila, PH (02) 285.98.80-96
    -Subic, PH (047) 252.35.11
    -Cebu, PH (032) 344.07.38
    -Bacolod, PH (034) 433.49.10
    -Zamboanga, PH (062) 993.19.05
    -General Santos, PH (083) 552.55.04
    May 2009
    #910
    dvldoc, what can you say about valvoline 15w40 CF-4?.....i've found out that a CF4 is the better one if not the best to use for a turbocharged diesel.
    May 2009
    #911
    i think i'm having another problem with my bosch fuel filter....engine jerks/shudders when accelerator is released suddenly from high rpm......there was this one time the fuel gage was below Empty and i filled it up with 50 ml 2T and while travelling to the gas station (10 km away), tried to overtake and engine shut off suddenly....something like someone reached for the key and turned it off then on again. suspected it was air that entered the fuel system (due to below E on the gage)....trouble showed up again i think 3-5 times even with the tank full. problem occurs when engine is revved suddenly or in constant high rpm. does not show on cruising speed...what's your suspicion sirs? could a soft hose coming from the tank to the filter-separator assy be the cause?
    Dec 2007
    #912
    Quote Originally Posted by miked View Post
    CF-4 has a robust additive package, higher lubrication than current oils, That API rating has been obsolete since 2008 so if it has a API star on it that oil is 3 to 4 years old already. Still safe to use but i would not use any oil that is more than 5 years old there simply because the higher the temp the oil is stored the more oxidation you will get in the oil.
    But if it was stored inside a store it's good for about 10 years.
    May 2009
    #913
    I'm buying valvoline oils from SM Ace so i guess the oil is stored properly......
    Jun 2007
    #914
    Hi doc, I think its a different case here in RP, because they still brew oils with CF-4 rating because it still in the required oil specs of the local manufacturers......and I think the CJ-4 is not even in full blast marketing here....
    Dec 2007
    #915
    I guess it is different overseas I learn something everyday. But CJ-4 will have a fat additive package, but for newer diesels with catalytic converters can shorten CATS life by about 25%.
    May 2009
    #916
    the highest API rated oil i encountered so far is the new DELO gold multigrade semi synth. CI-4 afaik....my suking auto parts dealer told me its the chevron delo 400 in the US. but i still prefer the mineral multigrade of Delo. Delo sport synth i saw one at a servitek dealer too with CJ4/SM rating iirc.
    Dec 2007
    #917
    Jan 2011
    #918
    Hi Doc, between Delvac MX and TDT, TDT is still better? TIA.
    Jan 2011
    #919
    Hi Doc, for the OCC on the Monty 4D56, will connect this to the breather hose? No PCV on the 4D56? thanks again.
    Dec 2007
    #920
    Yes it connects to between the breather hose and intake hose. Diesels don't have PVC valves.
Remote bypass oil filtration
