Page 44 of 67 FirstFirst ... 3440414243444546474854 ... LastLast
Results 861 to 880 of 3899
    Dec 2010
    It looks real naman.
    Thanks sir CB, i told the guy at the store that i needed an oil filter, baldwin, and before i can even finish my sentence to tell him what my ride is, he interrupts me already and asks, "taga tsikot ka noh?"
    Dec 2007
    I second that.
    Dec 2009
    I second that.
    Doc, can you help me, i can't find any available heads for the bypass filtration. Im planning to use 3/4 center thread, but it seems all stores doesn't carry it,
    Im also planning to put engine oil bypass like what you have in your ride, i like the amsoil package, or the perma cool type. Doc, how much does the bypass kit from amsoil cost in there, in the U.S?
    I saw the pictures of the duramax engines with the bypass filters from amsoil, i think their straight forward in terms of installation, problem is the availability of the parts or kit here locally.... Thanks Doc
    Dec 2007
    Quote Originally Posted by miko101130 View Post
    Depends on what your putting it on. If it's a 4m40 engine it won't work due to the M26 thread pattern.
    You can use the permacool set up on any of these sizes.
    3/4"-16, 13/16"-16, 1"-12, M18 x 1.5, M20 x 1.5 and M22 x 1.5. Designed to use oil filters with 3/4"-16 thread.
    How every if your going to do a bypass I would recommend using a adaptor and running a 1-16" thread filter.
    SINGLE Oil Filter Mount System
    Adapter here.
    PH3976A Oil Filter Converter~1"-16 X 3/4"-16 Bypass 2u FM | eBay
    Then run either a Baldwin B7317 or the even better LF9028 (which I run) both are 5 micron bypass filters, the Baldwin is 5 microns at 50% the fleetguard is 98% at 5 microns. Fleetguard double the price. I actually have 3 of the B7317's in the Philippines which I probably won't use anytime soon because it's going to take a long time to get 25000k on my van.
    Cheapest place for both of these is Welcome to Filterbarn™ | Discount Oil Filters | Discount Air And Fuel Filters | Heavy Equipment and Diesel Engine Filters you can get the baldwin for less than 12 bucks.
    You can also go with something like this as well but if it's on a SUV the hose might be a bit short. plus harder to mount.
    ALUMINUM 10AN AN10 ENGINE OIL FILTER RELOCATION KIT MALE+3X STAINLESS STEEL LINE | eBay
    You can get your 8AN fitting here.
    JIC/AN adapters
    and go with pushlok which also work awesome
    Pushlock Fittings
    You would need 4 3/8" to 8 JIC for the adapters.
    And the 4 pushlock 1/2 ID to 8 JIC and get your hose locally, A hydraulic shop is the best place to go for this.
    Or get the hose as a already complete assembly like I did from Surplus Center - Hydraulics, Engines, Electrical and More
    Surplus Center - 1/2" X 36" JIC 8F X JIC 8F 3500 PSI HYD HOSE
    Or you luck out and find a hole kit like this for cheap. which is a dual filter permacool set up. Which is what I use with the 1-16" adapters. But you can go with a normal filter for the first one and this will make your bypass last much longer.
    OIL FILTER RELOCATION KIT DOUBLE TWIN FILTER PERMA COOL 10795 | eBay
    You can do a whole kit if you know where to look and how to do it for under 6000P but then you got to get it to the Philippines so I would use pobox.ph and your set.
    Dec 2009
    Adapter here.
    Doc, Im putting the bypass filter on the transmission fluid on my everest (WL-T engine)... right now im ordering in singapore for a 3/4-16 center thread filter head...
    but im also contemplating of ordering another set of filter head for the engine oil bypass... its really a pain here to get the parts,
    i have already called volmax (baldwin)/ Pacer(fleetguard)/ even Paleeno (donaldson) and they have none whatsoever of any type of filter head assemblies...
    Doc, heres the site of the one in Singapore, im ordering the head and would take two weeks to arrive...
    Griffin Group International Pte Ltd
    Any points to consider when running a transmission fluid bypass filter Doc?
    Doc, can fuel filter media be used to run a bypass filter for a transmission fluid? is that ok or not?
    thanks
    Jul 2012
    hi dvldoc, a bit off topic.
    hi have a good day
    dvldoc attached herewith are various part number of filters. please source me these and indicate the price respectively and as soon as i received your reply. please let me know if could order it from you.TIA
    Part Number Manufacturer Description
    BF954 BALDWIN Fuel, Spin-On
    BF1275 BALDWIN Fuel/Water Separator with drain
    BF1233 BALDWIN FS1253 Fuel/Water Sep Spin-On (i want with WIF sensor)
    FS19519 FLEETGUARD Fuel/Water Sep Spin-On (i want with WIF or just a drain plug is okay)
    FS19594 FLEETGUARD Fuel/Water Separator with drain
    P550550 DONALDSON Fuel/Water Separator with drain
    Dec 2007
    Quote Originally Posted by marq View Post
    hi have a good day
    Though I don't mind helping people this is something you can google.
    You can find all these here. This is the cheapest place to get them. Baldwin Filter BF954 Fuel Filter
    Just type in the part numbers. You can find pretty much all of these on these two sites or you can go by Volmax in Manila to see if they have them in stock. I am currently in the US. You can use pobox.ph if you wanted to order them from the states.
    Be aware Baldwin filters are just about the best for fuel filters so they are not cheap. I prefer Baldwin over fleetguard and Donaldson when it comes to the fuel filters unless its a FS series Fleetguard which is microglass.
    Jul 2012
    okay thanks dvldoc.
    Im doing a mod..hehe.. tapos na ako sa planning stage... I'll be putting up a transmission filter for the transmission fluid of my eve...
    before kasi fuel filter ang mod ko, using fleetguard components, 1 year na toh. super linis fuel going into engine.
    now transmission fluid line naman lalagyan ko...
    i'll be placing it sa return line coming from the transmission cooler,
    i'll be using either 3/4-16 thread or 1-12 thread for the head assembly depending on what is available locally...
    then yung transmission filter body will be a hydraulic/transmission type media
    Head part number 3/4-16 thread= ST1025HH (fleetguard)
    media= B2/BT9388/BT420/BT8916/B163/BT8493/BT8908/BT8323/BT8409/BT8905/B252/B34/BT5/BT8301
    Head part number 1-12 thread= FS1241B (fleetguard)
    media= BT8499/BT9561/BT9553/BT357/BT346/HF35139/HF6119/HF6120
    i hope matapos ko within this week.. hehehe...
    Miko, ok yan. Wanted to do the same sa Pajero ko before. But plans didn't push through hehe after you do it, might do it also hehe
    Quote Originally Posted by krv214 View Post
    Sa volmax ba yan? If owner kasi naghahanap, alam na nila na tsikot yan hehe their usual clientele kasi are heavy machineries kasi. So halos puro mechanics bumibili hehe
    Dec 2010
    yup sir! ah kaya pala ganun, nung tinanong niya ako, napangiti lang ako tapos sinabi ko na kung ano kailangan ko. medyo doubt pa nga ako nung una, hehe tagal kong binusisi yung binigay niyang stock. naka box lang talaga siya boss? walang plastic yung filter??
    Yes sir. Walang plastic talaga
    Dec 2010
    ok thanks sir CB!
    Dec 2010
    I second that.
    Thanks doc!
    I think you have your filter number mixed it's not a B2 maybe you mean a BD28. The gaskets on those two are different the thread pitch is the same. It may or may not work due to the gaskets size difference you might have a leak.
    - - - Updated - - -
    Sorry incomplete info. Thread pitch will not matter and I know filters have different pitch. The relocator has replaceable pedestal (I can't remember what you call the thing you screw your filter on.) so I can use either pitch what I need is for the gasket to hit the lip. The b2 seals on the lip well but has a lowered psid. You think I can use the b2 to replace the original filter?
    Sent from my GT-I9100 using Tapatalk 2
    Dec 2007
    Quote Originally Posted by edtf View Post
    The B2 is not a dual flow filter it's a full flow. They way you can tell this also on Baldwin part numbers is the D in the part number means dual flow.
    thanks!! dvldoc
    Guys i still have one piece of bd28... Pm nyo ako if interested...
    Nag iisa na lang... Sayang naman, matatagalan pa uli bago meh dumating..
    Anyone interested with BD28? I have three available. PM me.
    Sorry OT
    full na inbox mo sir,
    Quote Originally Posted by tuazon7 View Post
    Hehe...got 2 LF3564 bought from filterbarn US, PM me for those who want it...hindi kasya sa rig ko tumatama sa intercooler hose kasi...mas wider sya compared sa BD28
    PM sent, mga sir.
    Guys anong equivalent ng BT223 sa Fleetguard? Hehe just curious.
    Dec 2007
    lf3335 is the bt223 equivalent
Remote bypass oil filtration
