nice thread, learned a lot. now im better informed (excuse me mr. lao) to protect our Innova D4D family car
just several questions sir, (i really had headache last night while reading those part code)
1. for Volmax Nr: 2448425 or 2448375 (am i correct)
2. baldwin oil filter for the 2kd-ftv of innova 2.5L D4D is BT223?
3. any update for fuel filter in D4D, fleetguard or baldwin?
TIA
sir san po makakabili ng Baldwin Filter or Fleetguard para sa 2.5 Montero Sport?
Careful using the JS filter site, it's not 100% accurate, I have already found several errors on there.
The 2kd-FTV is one of those, it shows the Badwin B132 which is closer in size to the B34, but then it shows the Fleetguard LF3460 which directly crosses with a BT223.
You got to double check on that site or you will wind up with the wrong filter.
yeah doc is right, as i was researching on js its not that exact to much, only last night i appreciated the js cross referencing
as i was going to reply and thanking RT and doc the transformer of the electric power supply bog down, wew i thought i going to ventilate my kids manually by hand through the night,luckily before 0100H power was restored...BTW ty guys
is the size of o ring matters also?
There is only a certain number of gaskets, but if something is a much larger OD then the gasket will be different but say for instance the BT223 is smaller than the B34 but they have the same gasket. If you physically have the extra space then you could actually use the B34.
I stacked them so you can see what I mean.
Always go bigger if you can. Especially with many vehicles having a odd size fill capacity like 8.2 liters or 4.7 liters. (i hate that) now you got extra oil left over. Get a bigger filter and get your moneys worth.
i dont know how you get BT223 from JS site, but its really the close match to the innova, as i inspected for room of B34 it can accomodate but the lip/rim/OD (i dont the term) will be just like hanging, sorry cant share pics for i dont have digicam.
im getting B132 and BT8409 when searching 2KD-FTV...
the OD of the 2KD-FTV OEM oil filter is ~78cm or 3"
BEST MATCH FOR INNOVA is BT223,
size of BT8409 is a perfect match in terms of OD and thread but the description in the baldwin catalog is "Lube or Transmission Spin-on" not full flow
tnx for the help guys, now im will add it to itinerary when going to manila to buy a good oil fuel filter, guess i gonna go for vic fuel filter
Hi All!
I got these from Volmax just a while ago:
The B2 oil filter:
The BF7535 fuel filter:
Are they legit?
Will be changing our the oil filter every 10K and the fuel filter every 30K as per dvldoc's recommendation. Will be using Shell Rimula X Black 15W-40.
