Page 32 of 67 FirstFirst ... 2228293031323334353642 ... LastLast
Results 621 to 640 of 3899
    Dec 2007
    Thats not impressive specs at all.
    Dec 2007
    I have tons of the for the ph8 cross reference
    Jan 2012
    awesome! spare me at least 4 of those bro. i'll ask my dad to wait till i get those from you on his oil change.
    he got excited when i told him about the T2 lessening the noise and rattle on his truck. its ridiculously noisy and we just hate the damn thing. 200:1 as advised is our plan of dillution.
    May Baldwin oil filter equivalent ba for Hyundai Starex D4CB crdi?
    ^ ano OEM part number mo. JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C109J yan ata yung counterpart eh.
    Check mo yung data sa current oil filter mo. If vic c109, yan na nga data.
    Found this over the net. Iba talaga yung quality ng US made products na oil filter.
    Wix Filter/NapaGold Oil Filter vs K&N: FleetFilter Secure Online Store
    Damay ko na rin, is the BD28 compatible with the Grand Starex Engine?
    Aug 2006
    Quote Originally Posted by araks99 View Post
    Starex D4CB crdi has the same filter thread size as that of Mitsu 4D56, 4m40 and 4M41 which is M26 X 1.5. So Baldwin BD28 (combo filter) is compatible. The Hyundai OEM filter is only full flow so BD28 (full flow + bypass) is one step better in oil filtration.
    Since BD28 is hard to find, I use Bosch OM 084 and change it every 5K km since the efficiency rating is not available (just to be safe). However, I change my oil (Caltex Delo Gold Ultra 15W-40) every 10K km.
    CMIIW, but both Starex crdi (non-vgt) and crdi vgt share the same D4CB engine configuration so they have the same thread filter size. They only differ in the turbo design.
    Hope this helps.
    Quote Originally Posted by lolo pepe View Post
    Hope this helps.
    Thanks lolo pepe, I guess a full flow filter with the same thread specs will do for the GS. I wonder which one in Fleetguard or baldwin has the same thread size ... ? hmmmm
    Hope this helps.
    Yari, kaagaw na naman sa stocks ng BD28 mga naka-starex. hehe
    j/k lang po. More reason for volmax et al to stock-up on BD28's/BD7028 then.
    Dec 2007
    Yes the bd28 fits the starex
    I'm talking about the crdi vgt doc, I thought it was a different engine altogether from hyundai...?
    Dec 2007
    js filter has a good search engine
    Jun 2005
    b179 kinabit dun bro. pero kasya naman 1402. check ko uli bukas engine bay ng EK
    Jun 2005
    p295 na pala ang b179. p215 pa din ang bt223. went to volmax this morning
    Dec 2007
    I also use old hard drive magnets, they are not going to move no matter what you do driving. Those other filters are a bit of a waist of money. especially if they only filter as good as OEM.
    Aug 2004
    Engine room of the BRP del Pilar
    ^ Binili daw nila sa Pacer? :D
    Aug 2004
    Patay tayo dyan. Paging COA! :hysterical:
    They were overhauled prior to turnover so most likely orig US pa yan. Problema sa next oil change hehe.
    VIC nalang daw sila sa next OCI.
    Jun 2007
    Im pretty sure dvldoc would be more than happy to donate a filter or two to the navy....
    but it should only be on the first oil change....
Remote bypass oil filtration
