Results 5,681 to 5,690 of 6300
- Nov 2009
- 3,057
January 6th, 2019 01:49 PM #56812 family mechanics na ang na deads without any symptoms of whatsoever and we attribute it to long exposure to auto chemicals including oil. With the oils full of additives and detergents who knows what kinds of harmful elements are there pero sa SMDS data sheet may warning na rin dun to avoid contact. As most doctors would say also, kahit rubbing alcohol when absorbed by the skin would end up in the liver.
The nitrile gloves are re-usable if properly cleaned with joy diswashing liquid.
January 6th, 2019 01:56 PM #5683
January 6th, 2019 01:59 PM #5684
January 6th, 2019 06:31 PM #5685
Speaking of magnets, Dimple has a product called Super Black Hole one can install around the oil filter.
Engine Oil Filter Magnets
January 6th, 2019 11:04 PM #5686
No offense, at $35, those are probably the most expensive magnets I've ever seen.
We purposely point the north pole of the magnet toward the oil in all our magnets. We have special proprietary reasons for doing so. The new Super Black Hole has a patent pending for using both sides of the magnet to one side, doubling the effective strength.
Just get the magnets from Lazada. They have 2 x 1 cm rectangular Neodymium magnets for like under P400 for 10 pcs. It can be shared between 2 to 3 cars.
January 7th, 2019 12:14 AM #5687
None taken, sir. Dimple magnets are no ordinary ones. High temp & roughly 1400x stronger than OEM magnetic plugs. You won't appreciate em w/o having tried.
Dimple Magnetic Drain Plugs: A Better Choice for BMWs & MINIs - YouTube
Magnet Oil Drain Plug Weight Capacity V2 - YouTube
DIMPLE MAGNETIC OIL PLUGS - YouTube
- May 2006
- 1,601
January 7th, 2019 01:09 AM #5688Neodymium magnets are the strongest in the world.
January 7th, 2019 01:15 AM #5689
January 7th, 2019 08:47 AM #5690
I think that the Dimple oil filter magnets are a scam. Even without magnets, the oil filter is already trapping dirt down to a certain micron and the engine will last long even with just oil and filter changes. Adding magnets may help a bit on the filter’s dirt carrying capacity but to spend $35 on them when there are cheaper alternatives?
I am not saying it’s not doing anything. I’m saying that it’s too expensive for the amount of work it is doing. Even if what Dimple claims is true about how powerful and heat-resistant their magnets are, then just put 10 Lazada Neodymium magnets on your filter and you only have to spend just a little over $7.... 1/5 the price of the Dimple oil filter magnets.
If you’re already using Dimple products, congrats. I guess you’re more well off than I am. As for me, I don’t think I will ever spend that much for magnets.
Bong Go to the rescue?
[AI] Here's what they'll check during MVIS...
