Page 572 of 658 FirstFirst ... 472522562568569570571572573574575576582622 ... LastLast
Results 5,711 to 5,720 of 6580
    #5711
    Merong malapit sa amin na Total Lubricants which offers low priced engine oils since they have some oils in drums which may be sold per liter. I intend to have a change oil soon for my 2016 Fortuner Diesel. Sa manual ang recommended viscosity is 5W30, which is fully synthetic. Now, they are offering me in Total Lubricants the mineral oil with 15W40 viscosity which costs only P190/liter but I have to do change oil every 5,000km as well as change the oil filter. Since I really intend to have my PMS every 5,000km and not the 10k for the fully synthetic which casa recommends, I am inclined to use the mineral oil with 15W40 viscosity from Total which costs only 190/L.
    Here is what Total offers me: RUBIA TIR 7400 15W40 with the following specs:
    MINERAL OIL
    High Performance Diesel Engine Oil
    Suitable for modern engines including those with exhaust gas recirculation (EGR) system
    Adapted to the most severe driving conditions
    Provides excellent viscosity stability and effective engine protection
    Provides effective control of soot, sludge and piston deposits
    SPECIFICATIONS
    API CI-4/CH-4/SL
    ACEA E7
    Here is the link: Rubia TIR 74 15W4v | Total in the Philippines.
    Should I go for this?
    Quote Originally Posted by attyallanlatras View Post
    MINERAL OIL
    SPECIFICATIONS
    API CI-4/CH-4/SL
    ACEA E7
    what car? what does the owners manual say?
    #5713
    2016 Toyota Fortuner Diesel. Recommended is Fully Synthetic na 5W30, but the mineral oil offered by casa os 15w40, which is the same sa Total Lubricants na tag P190/L...
    #5714
    Besides viscosity, check the manual for ACEA, API, ILSAC, SAE specs/classifications. Follow OE recommendations.
    #5715
    Besides viscosity, check the manual for ACEA, API, ILSAC, SAE classifications. Follow OE recommendations.
    Sir, sa manual ng Fortuner ko ang nakalagay ay: Oil Grade: API CF-4, CF or ACEA B1;
    on the other hand, sa Total Mineral Oil is: API CI-4/CH-4/SL ACEA E7...
    Now what do those mean? Noob here pasensya na...
    Feb 2012
    #5716
    Has anyone tried the MAG 1 brand? I saw this on sale yesterday at a handyman store:
    MAG 1(R) Full Synthetic 5W-30 Motor Oil
    The 4 liter package is at 2,000 SRP. At 30% discount, 1,400 na lang.
    This is what I am using right now - the MAG 1 5W30 Fully Synthetic. Sale ko rin nabili at Php1,400. Php2,000.00 ang regular price sa Handyman pero nagbaka-sakali pa ako sa Ace Hardware at mas mahal pa pala doon at Php2,500++. So okay na sana ako sa Php2k yun pala mas discounted pa.
    I think Grp. III based lang ito kasi meron pa silang European Formula naman which is mas mahal. It still falls though in the fully synthetic category as defined sa US standard. Can't really say how good (or bad) this oil is since wala din naman akong naging issue dun sa dati kong ginagamit na Ardeca FS 5w30. No difference I could feel with the MAG 1 this time.
    #5717
    The E7 is spec'd for diesel engines w/o DPF. Total Mineral you mentioned is also heavier than the recommended viscosity. Your FC will likely take a hit. Try to look for an option that satisfies what the manual states...though the specs like CF4 & B1 may have already been superseded by newer API & ACEA sequences, respectively. 5w-30 is more common here as Full Synthetic than mineral.
    Jan 2016
    #5718
    Any info about Gulf Formula G SAE 5w40 FS API SN? Was forced to use this as it was the only available oil at the suking talyer. Pretty expensive at 1,900/4liters. The synthetic blend was only rated SL so could not use that. Toyota synthetic blend of the same values was 1,600/4 liters.
    #5719
    Has anyone used MITASU ULTRA DIESEL CI-4 5W-40 100% Synthetic? I saw it at Blade for P1899.00 per 4 liters. Is this a good synthetic oil?
    here is the link for its complete description: MJ-212. MITASU ULTRA DIESEL CI-4 5W-4 1% Synthetic - MITASU OIL CORPORATION, JAPAN
    The manual for my vehicle (Fortuner) recommends 5W30 Fully Synthetic with the following Oil Grade: API CF-4, CF or ACEA B1
    On the other hand, the MITASU is 5W40 Fully Synthetic with the following Oil Grade: API CI-4/CH-4/СG-4/CF ACEA A3/B3, A3/B4, E7
    Should I go for the MITASU?
    most api sn oils for gas engines are ok. unless you have a turbo engine that requires acea or diff spec. 5w40 is alittle to thick imo
Mineral , semi synthetic or fully synthetic?
