Results 5,681 to 5,690 of 6542
January 6th, 2019 01:42 PM #5681
^buti nalang pala i wear nitrile gloves bro
ganun pala ka delikado yun? bakit di nag iingat mga kanto mechanic O_o
- Nov 2009
- 3,484
January 6th, 2019 01:49 PM #56822 family mechanics na ang na deads without any symptoms of whatsoever and we attribute it to long exposure to auto chemicals including oil. With the oils full of additives and detergents who knows what kinds of harmful elements are there pero sa SMDS data sheet may warning na rin dun to avoid contact. As most doctors would say also, kahit rubbing alcohol when absorbed by the skin would end up in the liver.
The nitrile gloves are re-usable if properly cleaned with joy diswashing liquid.
January 6th, 2019 01:56 PM #5684
January 6th, 2019 01:59 PM #5685
January 6th, 2019 06:31 PM #5686
Speaking of magnets, Dimple has a product called Super Black Hole one can install around the oil filter.
Engine Oil Filter Magnets
January 6th, 2019 11:04 PM #5687
No offense, at $35, those are probably the most expensive magnets I've ever seen.
We purposely point the north pole of the magnet toward the oil in all our magnets. We have special proprietary reasons for doing so. The new Super Black Hole has a patent pending for using both sides of the magnet to one side, doubling the effective strength.
Just get the magnets from Lazada. They have 2 x 1 cm rectangular Neodymium magnets for like under P400 for 10 pcs. It can be shared between 2 to 3 cars.
January 7th, 2019 12:14 AM #5688
None taken, sir. Dimple magnets are no ordinary ones. High temp & roughly 1400x stronger than OEM magnetic plugs. You won't appreciate em w/o having tried.
Dimple Magnetic Drain Plugs: A Better Choice for BMWs & MINIs - YouTube
Magnet Oil Drain Plug Weight Capacity V2 - YouTube
DIMPLE MAGNETIC OIL PLUGS - YouTube
- May 2006
- 1,668
January 7th, 2019 01:09 AM #5689Neodymium magnets are the strongest in the world.
January 7th, 2019 01:15 AM #5690
