Page 20 of 330 FirstFirst ... 101617181920212223243070120 ... LastLast
Results 381 to 400 of 6586
    Oct 2009
    #381
    ill stick to fully. sulit din e. d paservice ng paservice.
    Oct 2011
    #382
    Quote Originally Posted by vic2rem View Post
    I agree, maraming detergent kasi nga high sulfur ang diesel dito sa atin. That's why recommeded na oil is only API CF or CF-4 for toyota innova d4d diesel. Owners manual suggest an API CF or CF-4 for diesel Innovas here in the Philippines. Suflur ng Diesel dito sa Pilipinas is at least 500PPM, other countries 50ppm na lang. Kaya nga hindi EURO IV compliant ang diesel dito sa atin. Dirty Diesel causes the Suction Control Valve or SCV D4D dreaded problem. Toyota rectified the problem by improving and making the SCV bigger and longer and wont clog yong SCV. Mura lang naman paayos nito, less than P10,000 yata. Kaya nga lang you will never know when your engine will stall. High maintenance sa diesel, High Gasoline Prices sa Gas. Dami namang mekaniko ng diesel dito sa atin. Kaya just take your chancesna lang. As per Owners manual, Innova diesel oil recommended oil dito sa atin is API CF-4, CF, CD, CE and not those high API ratings for diesels API CJ-4, CI-4 PLUS/CI-4/CH-4/CG-4/ SM/SL/SJ ACEA E7.
    May mga diesel oil na hindi API SL, SM rated Not all diesel oil are recommeded for Gasoline engine and not all Gasoline oil are rated for Diesel engine. Meron mga Gasoline oil na SL, SM rated and also CF rated. So pwede sa Gasoline and Diesel.
    Recommneded oil for Innova from Owners manual.
    Gasoline engine: API SL, SM grade 5w-30 or 10w-30, 15w-40, 20w-50
    Diesel engine: G-DLD-1, API CF-4, CF, CD, CE
    Example of an Oil that is recommended for both diesel and gas engine
    Mobil1 has SM/SL rating for gas, CF rating for diesel
    From Mobil1 website
    Mobil 1 10W-30 meets or exceeds the requirements of:
    ACEA A1/B1, A5/B5
    API SN, SM, SL, SJ
    ILSAC GF-5
    Mobil 1 10W-30 is of the following quality level:
    General Motors GM-4718M
    General Motors 6094M
    API CF
    Check your owners manual for recommended oil viscosity and rating!!!!
    mga oil gurus, repost ko lang ung above quote from Innova thread. paki pansinin lang ung highlighted part. hindi ba compatible ang higher API rating like CI-4 for Innova Diesel? un pa din naman ang maganda na nabasa ko dito sa thread e.g. Delo Gold Ultra & Mobil Delvac MX. Ang alam ko ung API CJ-4 lang ung hindi pwede but API CI-4 or CI-4 plus should be compliant with Innova Diesel. Paki clarify lang. Thanks.
    May 2005
    #383
    CI-4
    Status: Current
    Introduced September 5, 2002. For high-speed, four-stroke engines designed to meet 2004 exhaust emission standards implemented in 2002. CI-4 oils are formulated to sustain engine durability where exhaust gas recirculation (EGR) is used and are intended for use with diesel fuels ranging in sulfur content up to 0.5% weight. Can be used in place of CD, CE, CF-4, CG-4, and CH-4 oils.
    You will notice that the manual still recommends API CD or CE, both of which are really obsolete.
    CI-4 should be compatible with the KD-FTV engines
    Oct 2011
    #384
    Thanks for the assurance sir. I was surprised when I read that particular post.
    #385
    i do not understand why are they recommending CD or CE, since the engine is already equipped with EGR.
    #386
    Sir, minimum requirements lang po siguro yung nasa manual. Especially for units in more developing markets than ours. Anything that exceeds it is suitable.
    Oct 2011
    #387
    I also wonder why it didn't mention CH-4 or CI-4 either in their recommended API rating.
    May 2005
    #388
    Exactly. If the Innova are equipped with catalytic converter then the more they should use API CI-4, if they want to prolong the life of the cat.
    Jan 2012
    #389
    Mga sir, kapag po ba nagpapalit na oil every 5,000kms interval eh need din magpalit ng oil filter? TIA
    May 2005
    #390
    Quote Originally Posted by carwhacko View Post
    A change of Oil filter is always done at the same time or in tandem with the oil change.
    Jan 2012
    #391
    Thank you sir!
    Oct 2011
    #392
    Buy a good quality oil and filter that could give you 10K+ interval oil change.
    Jan 2012
    #393
    I am going to use either petron rev x all terrain or caltex delo for my next oil change. For the oil filter I dont know where to find a good quality oil filter that is relatively cheap.
    #394
    Why not go for the branded oils like Motul and Mobil1?
    You're from Bacoor pala
    Oct 2011
    #395
    go for Delo 400 or Delo Gold Ultra instead of Petron Rev X. for oil filter, you could never go wrong with baldwin or genuine purolator.
    Jan 2012
    #396
    Sir masyado ata mahal yung Motul and Mobil 1. Haha parang hindi pa kaya ng budget.
    Yes po I am from Bacoor. :D
    Jan 2012
    #397
    Oh okay sir Delo Gold Ultra it is. Hmm do you know where I can find baldwin filters sir? Preferably south area sir.
    #398
    How much po yung Rev X at Delo? per liter
    Jan 2012
    #399
    *starex gold. Havent checked it yet pero I am guessing nasa 200+/liter siya eh. More or less.
    Oct 2011
    #400
    more than double the price pag FS oil.
Mineral , semi synthetic or fully synthetic?
