Page 569 of 658 FirstFirst ... 469519559565566567568569570571572573579619 ... LastLast
Results 5,681 to 5,690 of 6580
    #5681
    ^buti nalang pala i wear nitrile gloves bro
    ganun pala ka delikado yun? bakit di nag iingat mga kanto mechanic O_o
    #5682
    2 family mechanics na ang na deads without any symptoms of whatsoever and we attribute it to long exposure to auto chemicals including oil. With the oils full of additives and detergents who knows what kinds of harmful elements are there pero sa SMDS data sheet may warning na rin dun to avoid contact. As most doctors would say also, kahit rubbing alcohol when absorbed by the skin would end up in the liver.
    The nitrile gloves are re-usable if properly cleaned with joy diswashing liquid.
    #5683
    To avoid sudden death caused by oil getting into the hands and into the liver, some would invest on boxes of nitrile gloves.
    Also they invest on torque wrench for the correct torque of sump plug, some fluted oil wrenches for easy removal of cartridges, and boxes of tissue to wipe clean excess oil.
    +1[emoji106]
    damnit i alcohol too many times. good facts bro
    #5685
    thanks sa warning. sana si dr.d maka chime in re: skin penetration ng chemicals
    #5686
    Speaking of magnets, Dimple has a product called Super Black Hole one can install around the oil filter.
    Engine Oil Filter Magnets
    Jan 2009
    #5687
    No offense, at $35, those are probably the most expensive magnets I've ever seen.
    We purposely point the north pole of the magnet toward the oil in all our magnets. We have special proprietary reasons for doing so. The new Super Black Hole has a patent pending for using both sides of the magnet to one side, doubling the effective strength.
    It must work like a PowerBalance bracelet for your car.
    Just get the magnets from Lazada. They have 2 x 1 cm rectangular Neodymium magnets for like under P400 for 10 pcs. It can be shared between 2 to 3 cars.
    #5688
    None taken, sir. Dimple magnets are no ordinary ones. High temp & roughly 1400x stronger than OEM magnetic plugs. You won't appreciate em w/o having tried.[emoji4]
    Dimple Magnetic Drain Plugs: A Better Choice for BMWs & MINIs - YouTube
    Magnet Oil Drain Plug Weight Capacity V2 - YouTube
    DIMPLE MAGNETIC OIL PLUGS - YouTube
    #5689
    Neodymium magnets are the strongest in the world.
    #5690
    Quote Originally Posted by istan View Post
    Dimples aren't regular neodymium magnets.[emoji4]
Mineral , semi synthetic or fully synthetic?
