Page 38 of 330 FirstFirst ... 283435363738394041424888138 ... LastLast
Results 741 to 760 of 6586
    Jan 2012
    #741
    Quote Originally Posted by seymorebutts View Post
    question lang po mga sirs:
    ang oil capacity ng sasakyan ay 6 liters, pero during change oil, nasa 5.20-5.50 lang nailalagay and sakto na sa dip stick, yung sobra po bang oil pwede ko pa gamitin sa next change oil? mga 3-4months ang tagal para 5liters na lang bilhin ko? or di na pwede at contaminated na?
    thanks
    or what you can do to avoid getting those excess, is to use the biggest filter you can find for your ride. in this way the supposedly excess can still be accommodated due to the larger size of the filter hence higher capacity.
    my ride will only take 3.6L of oil using stock oil filter, i used bigger filter, now its total capacity is 4L spot on. atleast now wala nako butal. I just hate it kapag may butal. hehehe
    #742
    thanks sir retz
    Quote Originally Posted by bayen View Post
    actually sir malaki na yung filter(OEM), ok lang kaya if i do it the other way around?
    #743
    double post
    Jan 2012
    #744
    thanks sir retz
    ahh... if thats the case, stick with the bigger filter. dont use a smaller one. if i may ask sir what type of vehicle are we talking about? im curious what aftermarket filters are compatible with your ride.
    #745
    kia carens diesel sir, i may have seen your ad pero wala atang pepwede
    Jan 2012
    #746
    ah ok. same thread as for my Honda. m20X1.5, so far the biggest one i can think of for your ride are the following:
    Baldwin B7243 - total oil capacity 400ml
    Fleetguard LF3528 or Baldwin B166 - total oil capacity 400-500ml, these two have a bigger outer diameter, around 3.6-3.7 inches which based on the Baldwin site, will fir your ride as it cross reference B173-S which has a outer diameter of 3.6in.
    i still have a couple of these lying around the house.
    Oct 2011
    #747
    I have been using the new CI-4 mineral oil for quite sometime now, parang wala naman ako noticed na difference.
    #748
    Butt dyno usually wala talaga. Dapat sa analysis may lumabas na difference hehe
    Jan 2008
    #749
    CI-4 is not even new. Even the engine wont feel the difference. Maybe from mineral to FS oil baka meron pa,
    Wala talaga, pero after 10,000kms of use balitaan mo kami.
    Oct 2011
    #751
    Quote Originally Posted by Errol5 View Post
    Yup, I was expecting the engine to be at least much quieter with CI-4. Maybe I could see the difference with FS oil. When using FS oil, is it okay to revert back to mineral?
    Jan 2008
    #752
    Yes, Fs to Mineral or vice versa pwede.
    Jan 2012
    #753
    yeah, perfectly okay to back to mineral coming from fs.
    #754
    thicker oil will make your engine quieter. yan ginagawa ng buy and sell sa diesel engine. para tahimik.
    CI-4 rated oils contain more additives compared to lower rated oils.
    Jun 2005
    #755
    bakit sa caltex 245 delo ultra? based sa posts dito may less than 200 lang.
    btw, anybody know how to spot a fake delo gold ultra?
    #756
    Quote Originally Posted by sirkosero View Post
    same question, planning on buying too. May nakita ako sa sulit 900+ lang yung gallon, at meron ding 1120 ang isang 5L container...ayoko pasigurado eh...
    Sep 2011
    #757
    Mga guru's ok kaya yung mobil1 15w 50 FS sa alits nakita ko sa subic tig 12 dollars lang.
    Oct 2011
    #758
    Quote Originally Posted by Aiandi View Post
    50 is too thick na imo.
    #759
    Quote Originally Posted by ronki View Post
    Around P1200 din ang bili ko sa 5L bottle. Not sure if P1100 or P1200. May less 100 pa kasi nung bumili ako. Para sure, sa Caltex ka mismo bumili.
    Oct 2011
    #760
    thanks cb. i think 40 viscosity grade is already thick enough. pwede pa umakyat ng 50?
Mineral , semi synthetic or fully synthetic?
