Kaya bang tumagal ng 10kms ung zic rv? Palit oil filter ng 5k
using a high filter efficient oil filter such as baldwin or fleetguard you can easily extend oil change interval to 10,000 to 12,000km, however if you use a regular oil filter such as vic or oem, its safer to change every 5,000KM. My suggestion is, initially just use a baldwin right away so that you wouldnt have to change it until 10,000km mark.![]()
May napost na ba about Petron RevX All Terrain 5W40 kung pwede and maganda ang specs for gas engines?
Co Wikipedia:
Total base number (TBN) is a measure of a lubricant's reserve alkalinity. It is measured in milligrams of potassium hydroxide per gram (mg KOH/g).[citation needed]
TBN determines how effective the control of acids formed will be during the combustion process. The higher the TBN, the more effective it is in suspending wear-causing contaminants and reducing the corrosive effects of acids over an extended period of time. The associated measurement ASTM D2896 and ASTM D4739-06 generally range from 6-80mg KOH/g in modern lubricants, 7-10mg for general automotive use and 10-15 for Diesel operations.
So basically the higher the TBN the longer you can run it in your vehicle. So if you start with a whopping 16, you can run it for a long long time. I saw a used oil analysis, he used this oil on his trooper. ran it for 5,000 then had the oil tested, it registered TBN 14, that was after 5,000 KM, VIC pa gamit nyan oil filter, just imagine kung baldwin pa ginamit nya.
sir when you say it registered 14TBN using vic after 5k meaning malinis pa yung oil? sa tingin mo ba sir kung ganun it can last 10k OCI using bosch oil filter, meaning after 10k na rin palit ng filter? hehehe sorry kung pang dummy yung tanong trying to learn about this things...
Sirs, tama ba itong logic?
E.G. If I use a very good oil and a poor filter. Oil could last 10K but filter only 3K, pwede ba ung filter lang palitan every 3k? To my understanding, kailangan palitan both oil and filter kasi every OCI.
using poor filter with good oil defeats the purpose of using good oil. If you use bad filter, particles smaller than 30 microns gets recirculated back to the engine causing greater damage in the long run. Tbn will be still be high for good oil when you do oil analysis, but particle count for wear metals in the oil would probably also increase. Bosch filters are good over the counter filters as good if not better than oem but not up to baldwin or fleetguard stardards. Mura lang naman sya so changing it every 5k is extra safeguard. Kung walang makuhang baldwin yan gamit ko
Wala dapat tatapon na langis pag tinangal mo filter (konti cguro galing sa cavity between filter and filter housing base). Kasi nasa crankcase ang oil mo. Kung wala o non functioning ang anti drain back valve ng filter mo tatapon yung langis na nasa loob ng filter habang tinatangal mo sya gaya ng sa VIC filter.
