Comparable ba Bosch Premium sa Baldwin? Mag switch na ko from oem dahil sa nabasa ko sa bitog.
ano nabasa mo sa bitog sir? I think baldwin/fleetguard is a notch higher than bosch.
Pls recommend a "bang for the buck" engine oil for fortuner 2.5vnt diesel
Not so cheap nor expensive
Prefer frequency of change every 5000km
Tried: delo gold
Result: poor fuel efficiency loss 2km/L
Tried: oem toyota mineral oil
Result: better than delo gold
may effect ba talaga ang motor oil sa FC? I mean using different brands of mineral oil having same oil viscosity?
How much ba ung Top1 FS oil? I think mura din un kung yearly OCI mo.... pwede rin un. Instead of every 6 months mineral oil.
Aside from viscosity, tingnan nyo rin yung api at jaso rating ng oil nyo. Yung besco multi z ng trooper api cd ang grade. Yung bagong besco duramax, api ch na yung rating. ( jaso dh-1)
Ry_tower & Retz: Thanks, i'll try them both since comparable naman sila, mas mauuna lang siguro ung baldwin kasi may makukuhanan locally.![]()
Met with alex of caloocan standard. he is selling Kixx oil Ung Kixx Turbo RV FS oil nila Php250/Li. Good for 10K na daw un and every 5K change lang oil filter. Need pa ba change filter every 5k kung baldwin naman ang gamit na filter? Has anyone use this in their D4-D engine?
^Given that the BT223 is priced about half of what the OEM Toyota filter being supplied from the dealer, why not?
