Page 14 of 330 FirstFirst ... 41011121314151617182464114 ... LastLast
Results 261 to 280 of 6586
    May 2005
    #261
    Quote Originally Posted by miko101130 View Post
    depende kasi sa market...
    the ESP are suited for EURO type of cars and consumers who are super concern about emissions and the environment...
    while the 0w40 are generally regarded as all around performer...
    dahil global leader and mobil sa retail nang engine oils, madami sila line up for different markets and different cultural preferences by consumers...
    The 0W-40 is actually labeled for European cars(in North America).
    Mobil 1 0W-40 (European Car Formula in North America) meets or exceeds the requirements of leading industry and car manufacturers’ standards required for newer modern gasoline and diesel powered automobile engines.
    Mobil 1 0W-40 meets or exceeds the requirements of:
    API SN/SM/SL/SJ
    ACEA A3/B3, A3/B4
    Nissan GT-R
    Mobil 1 0W-40 has the following builders approval:
    MB-Approval 229.3
    MB-Approval 229.5
    BMW LONGLIFE OIL 01
    VW 502 00
    VW 505 00
    PORSCHE A40
    Mobil
    According to ExxonMobil, Mobil 1 0W-40 is of the following quality level:
    API CF
    VW 503 01
    SAAB
    OPEL Long Life Service Fill GM-LL-A-025
    OPEL Diesel Service Fill GM-LL-B-025
    FIAT FIAT 9.55535 – M2
    FIAT FIAT 9.55525 – N2
    FIAT FIAT 9.55535 – Z2
    Aug 2007
    #262
    Mga sir any thoughts regarding HKS oils? Dami kasi nagsasabi na okay daw. Dami din may gusto mag try kasi HKS ang brand.
    #263
    Guys and experts, may nabasa kasi ako na parang alternative sa engine flush daw. Ang sinasabi, kapag you're using FS oil and nearing the 10k kms of use, nagpapalit sila ng Petron MO40 oil siguro sa 9k kms (basta near the change oil schedule) but without changing the oil filter. Then sa 10k, change oil again to FS oil and change oil filter. Ok lang ba tong gawin? Switching from FS to ordinary then back to FS? Sabi kasi nila maganda raw 'panlinis' yung Petron MO40. Thoughts on this po? Car is an 08 Vios pala. TIA.
    Nov 2011
    #264
    Mga bro. saan kayo nakaka bili ng magandang oil? Wala akong mahanap malapit dito sa amin! Mga el cheapo lang meron dito !
    May 2005
    #265
    Delo Gold Ultra costs Php 1,275.00 for 5 liters or Php 255/li. Price is a bit higher. At a station in Rizal Ave.
    Is this possible to do 10,000 kms with a Baldwin on this oil? API CI-4
    Yes sir, kayang-kaya. These are fleet designed oils for extended oil drain intervals.
    Dec 2009
    #267
    bro, the Mo40 that you're talking about is not a good oil to be used sa mga vehicles na 4 stroke especially with current setup nang engines (gasolines) ,... ginagamit namin yan M040 (motor oil 40 ata yan) sa mga lawnmower at waterpump namin sa bukid...
    plus monograde pa yan.. so ang tagal nyan mag flow sa oil system mo, possibly abutin yan nang mga 8 seconds para maka flow past the filter and all oil passages...
    In my opinion, its a risk on you're part para subukan mo sa auto mo...
    a GOOD engine oil will provide the necessary cleaning power that you are looking for...
    fully synthetic engine oil has excellent if not the best ability to clean you're engine and maintain its cleanliness...
    Pero if want to flush, based on my experience dalawa lang products na i can vouch for cleaning engine internals, either you use
    Auto-RX or liqui moly flush plus....
    sa auto -rx no doubt sa capabilities niyan.. highly regarded yan both locally and internationally....
    kung hindi naman matindi sludge mo at engine varnish, FS oil will surely clean that, give the FS oil at least 2 oil changes and meh improvement na yan...
    #268
    Quote Originally Posted by GunnerJam View Post
    based on what i've read, you're better off with the more established brands. for the same price or less, you can get a fully synthetic with API SM rating and manufacturers' approvals.
    May 2005
    #269
    Delo 400 is Php 1,675 for a 5 liters bottle.
    Aug 2007
    #270
    *onewaytrip oo nga sir may nabasa din akong hindi daw maganda. Naiinis kasi ako sa mga friends ko porket HKS daw ok daw yun. Eh hindi nga nila alam kung ano laman nun.
    *number001 ako sir kakabili ko lang ng delo 400 kahapon 1300 lang yung 5L tapos 265 yung 1L bottle. Dito sa isang auto supply sa mindanao avenue.
    Caltex station? P248/ltr lang sa auto shop na supplier yan eh.
    Oct 2011
    #272
    mukhang magkalapit lang ang presyo ng Delo Gold Ultra and Delo 400. Sa Delo 400 na ako kung ganon.
    May 2005
    #273
    Yes Caltex Station. Really expensive talaga. The Delo Gold Ultra price is from a station in Rizal Ave. The Delo 400 is a station in Malabon area.
    Dont know about the auto supplies, but there have been reports of counterfeits around.
    Its a shame we don't have a reputable, stable seller of lubricants at reasonable prices in the Philippines.
    #274
    i have a 1st gen kia sportage kr2 2.0l diesel MT. With mineral oil, i observed it gets thick and sticky after 2 months use, and the idling is rather low, engine is noisy on cold start( the idling will increase and noise will reduce after a while tho). with a fully synthetic oil, the idling and noise is already close to or same as at normal engine operating temp, so i use petron rev-x all-terrain 5w-30 fully synthetic oil at 6 months oil/filter change ever since.
    Oct 2011
    #275
    mahal pala sa Caltex. please post if you know any local caltex oil dealers here in manila.
    Oct 2011
    #276
    I noticed that most FS oil, the API rating is usually SL/CF or SM/CF. Why is it that there is no FS oil (correct me if im wrong) that is rated higher than CF like CH-4 or CI-4 for diesel?
    Aug 2007
    #277
    Sir afaik Mobil 1 TDT is FS and it's rated SM/CJ-4
    Dec 2009
    #278
    Sir, madame FS oil na CJ-4,CI-4,SL rated....
    pag ang oil kasi ay CI-4 only, usually semi synthetic lang....
    Mostly the FS oil ay either Cj-4 or SN specs na.... updated na kasi ang APi rating nila...
    Dec 2009
    #279
    Quote Originally Posted by limarj View Post
    Bro, there are other better oils other than rev-x all-terrain than can offer better performance and protection.... for the same or almost near price....
    you can try other synthetics which are rated at either 0w40/ 5w40/ 10w40,, these are better suited at our climates
    #280
    Sir thanks for the reply. I guess di ko na ttry to hehe risky pala masyado. Last change oil ko was mid January pa and since then 3k+ kms pa lang tinakbo ng oto, 2-3x a week lang kasi nagagamit since wala pa akong pasok. Ok lang ba na sagarin kong 10k or mas maigi mag change oil na before the year ends (in the -ber months)? I used Idemitsu FS oil from Unioil 5w30 on my last oil change.
Mineral , semi synthetic or fully synthetic?
