Page 7 of 330 FirstFirst ... 345678910111757107 ... LastLast
Results 121 to 140 of 6586
    Oct 2011
    #121
    Same price lang po yan halos if sa mga auto shop na malalaki kayo bibili. Delo Gold and R3 are both CH-4 rated, Delo Gold Ultra yung medyo nasa P190-220 ang CI-4 rated.
    Okay thank you sir. malaki pala patong sa ace kung ganon.
    Sobrang mahal sa Ace. Better get from a big auto shop. Yung ibang gas station kasi fuel lang yung direct sila sa principal kaya lubricants minsan mahal. Peor yung mga auto shop at oil stores lang mismo, mura yan.
    Oct 2011
    #123
    Thank you sir. I was in petron gas station earlier this morning and inquired about their diesel engine oil. Meron silang Rev-X Trekker multigrade mineral based oil 15W-40 which is CI-4 rated (Php278/Li). Is it on par with Caltex Delo Gold or Shell Rimula R3? How do you rate those three types of engine oil from good to best? Thank you for your inputs.
    #124
    mas sulit pala ang delo gold at Php200/Liter kumpara sa Rimula R3 na nasa Php260/Li.
    The last time I bought Shell Rimula X R3 from a Shell Gas Station near our village, which was last month for our GS's 15KKm PMS,- nasa P203 lang siya per liter.... Medyo mahal ang P260/L na nakita mo, bro.
    15.6K:weathermanf2:
    Sep 2011
    #125
    Mas okay sa climate natin and laso for older engines yung w40 viscosity. So better yang Delo Gold na SL rated naman. You don't need to worry about zinc levels since it i just about right at 1200ppm.
    Ah ok thanks. Almost 3 years na ako delo gold ginagamit sa civic ek.
    Oct 2011
    #126
    15.6K:weathermanf2:
    sa Ace ko kasi nakita ung Rimula R3 brad. Cge, tanong ko din mismo sa Shell Gas Station kung magkano. Nalilito na ako kung ano ang bibilihin kong mineral oil.
    Delo Gold Ultra ka na lang. Mura siya. Or Mobil Delvac MX basta sa auto shop ka bumili. Ci-4 rating nilalagay ng Petron pero wala yang API symbol na nagpapatunay na pasado sila. Claims lang nila yan kasi dapat may API symbol if pasado. Tsaka yun nga, problem with petron is you don't know its chemical composition. Stick to those with published product data sheet.
    May 2009
    #128
    Mas maige kung Delo 400 ka na lang kung ganyan din lang presyo ng Petron. P295/li ang bili ko sa Delo 400 (not the two Delo Golds ha).
    Delo 400 is API CI-4 plus/CI4/CH4/CG4/CF4/CF/SL afaik sa label nya plus other oil tests like MB, JASO, pati Cummins pa ata.
    TBN as per one pds is 12.6 tapos 10.5 naman yung nakita ko sa ibang pds pero i think that's the LE version which is CJ-4 na. or maybe yung 2 ASTM test yun with regards to TBN (D2896 and D4379). either way, considered pa rin na mataas yung TBN nya.
    Oct 2011
    #129
    Thank you sir, ano API rating ng Delo Gold Ultra and Delo Gold? based dito sa mga post seems like this is a good oil compared sa shell and petron.
    May 2009
    #130
    You may want to try also yung Valvoline oils sa ACE. cheap din at CI4 and cummins rated din yung mga ibang diesel oils ng valvoline. natry ko na din kasi yung valvoline turbo at P200/liter e.
    Delo Gold Ultra is CI4/SL
    Delo Gold is CI4 down to CF/SL to SF ata yun.
    correct me if i'm wrong dito sa post ko. nagbenta kasi ako lately ng mga junks sa bahay kaya wala na yung mga plastic containers ng oils.
    #131
    Base sa recommendation ng isang kaibigan naming engineer from THP na related sa oil industry,- use mineral oil in the first 10,000 Km - 15,000Km para mag sit properly ang mga components ng makina....
    And then shift to semi-synthetic and then fully-synthetic variants....
    15.6K:weathermanf2:
    Oct 2011
    #132
    15.6K:weathermanf2:
    Medyo hindi pa kasi ako kumbinsido na gumamit ng fully synthetic oil and pricey kasi. Well with the exemption of ZIC synthetic oil which is cheaper compared to other synthetic oil brands.
    Oct 2011
    #133
    Quote Originally Posted by miked View Post
    Actually I have been using the more popular Castrol brand mineral oil. Castrol CRB for old school diesel engine and the Castrol GTX Diesel for the CRDi powered engine. Eh may nabasa ako dito na "stay away" from Castrol, kaya tuloy naghahanap ako ng ibang alternatives. Hirap din pumili sa dami. Yes, I have seen the Valvoline mineral oil na CI-4 rated which is also cheap. But so far, mukhang okay at good choice ung Delo Gold or Delo Gold Ultra in terms of its quality and price among those in the mineral based oil category.
    #134
    Been using mineral engine oils-- Petron Trekker, Mobil Delvac MX, and Caltex Delo on our two 4JA1 vehicles. Pansin ko pinakamaganda ang andar using the Caltex brand.
    Currently using the Shell HX5 on the Crosswind. OK naman. Worst yon Petron Trekker.
    Oct 2011
    #135
    Quote Originally Posted by Gerbo View Post
    Thank you sir. Your experience using those different kinds of mineral oil will surely help us to decide.
    May 2005
    #136
    Where can the DELO 400 be purchased in Metro Manila? Best prices preferably. Caltex Gas Stations prices are not any lower. I hate buying from Ace bec of their prices and one time they questioned me for writing down the prices of their oil on a piece of paper (I was comparing prices).
    Can this DELO 400 along with a Baldwin Filter last for at least 12,000 kms bet. oil changes?
    Oct 2011
    #137
    That is what I'm thinking too. Solve na ako sa Baldwin oil filter. Now, need to have the best and affordable mineral oil in the market.
    Oct 2011
    #138
    A little off topic:
    Since maganda ang Caltex oil compared to the other "big 2" gas stations para sa engine, how about ang fuel quality? Does it also equates or translates to good fuel from Caltex? Doon kasi ako sa big 2 usually nagpapa gas, never pa ako nagpa gas sa Caltex.
    A little off topic:
    May separate thread regarding this. Common answer is just make sue the gas station is located in an area which is not prone to flooding (preferably elevated area) and has no history of fooling its customers.
    Try to ask Caltex HQ at Makati City. But Delo 400 plus Baldwin you can easily go 15,000kms. Dami sa Bob isThe Oil Guy forums na mga used oil analysis showing how oil performed after extended drain intervals. 8K-10K miles is common so mga 12k-16K kilometers yun. And the oil is still good.
    #140
    which is better, delo 400 or mobil mx?
Mineral , semi synthetic or fully synthetic?
