Page 87 of 93 FirstFirst ... 3777838485868788899091 ... LastLast
Results 1,721 to 1,740 of 1853
    May 2012
    #1721
    6 mos. of use is more than adequate time. I noticed a significant difference the following day after adding it to my tank. I don't understand as to why it didn't work for you. I would have to take a closer look at those injector pipes and hopefully no leaking oil. Appreciate your input.
    Apr 2015
    #1722
    No problem *kraulto. Im thinking about trying it out again. Just to satisfy my curiosity as to the prrofrmance boost by adding 2t in diesel fuel.
    On another note bro, how much did you spend for overhaul? I also have a paj 97 local 4d56.
    May 2012
    #1723
    Hopefully, this time around 2T will work for you. Spent total P106,690, labor and parts, all OEM. If ever the time comes that your engine needs an OH, can't stress enough the value and necessity of a TRUSTED mechanic. An unfortunate event i experienced, resulting in the early demise of my engine considering it was OH on 7/27/12, it was a simple oil leak but the mechanic told me it needed an OH, and then a 2nd one 10/25/2012, wherein the engine actually seized on me while on the NLEX, performed by the same mechanic as back job. Almost lost faith in all mechanics til i met my current mechanic. So in reality, this is the 3rd OH.
    Aug 2009
    #1724
    Very sorry to hear that sir. Why not try the services of known pajero mechanic like the guru, engr. Joseph atutubo? Just my thoughts po. Gd am po.
    May 2012
    #1725
    Thanks for the suggestion but tried him once, and never again. Very frustrating since he was highly recommended. Without going into specifics, he conducted himself in an extremely unprofessional manner, and his demeanor was unbelievably appalling.
    May 2012
    #1726
    I apologize for my rant and veer off topic. Any hypothesis on the possibility that 2t could've added to the early demise of my Injection Pump and is there any such detriment in using 2T for overhauled engines and newly calibrated IP's?
    Dec 2009
    #1727
    Quote Originally Posted by kraulto View Post
    anu ba reason at na-overhaul ang engine mo at injection pump?
    May 2012
    #1728
    The Engine displays Blow By symptoms. Since engine was already being overhauled, had the Injection Pump checked out. It was calibrated, gaskets and nozzles replaced, but not overhauled.
    May 2009
    #1729
    diko alam kung ako lang nakakapansin. tried again caltex diesel after a very long patronage with shell diesel. mas maganda response at takbo. diko muna nilagyan 2T.
    may halo bang naptha ang caltex diesel? o yung inaadvertise nila dati na janitors sa loob ng makina? hehehe
    Apr 2015
    #1730
    Kamusta fuel consump sir?
    May 2009
    #1731
    ^hindi ko po masasagot iyan dahil P500 lang ikinarga ko nung nasa E na.
    pero as per my last FT method e 14 km/li ang konsumo. may 2T man o wala.
    Apr 2015
    #1732
    Okay sir. Naiba ba talaga takbo sa caltex? Long time shell fuelsave user din ako e. Maybe its time to try caltex din?
    Aug 2013
    #1733
    Quote Originally Posted by miked View Post
    ganito din ako bro, Petron diesel naman. long time shell fuel save user din ako, nung kinapos sa fuel, no choice na kaya napakarga sa Petron. laking gulat ko din na mas responsive sa fuel save kahit walang 2T.
    Apr 2015
    #1734
    Quote Originally Posted by innova2013 View Post
    Mas responsive siya sa diesel max ng petron sir? Nag try ako sa petron din noon pansin ko mabilis maubos
    Aug 2013
    #1735
    Quote Originally Posted by paulomik View Post
    oo bro. sa dalawang naming sasakyan, innova at hilux (2L). doon sa hilux ko, mas matipid yung Petron diesel max with 2T compared sa Shell fuel save with 2T.
    2T ko pala ay Shell. kahit mapa Petron o Shell ang diesel na gamit ko.
    #1736
    TS,
    is 2T safe to use with trooper 2003(4jx1)? crdi na engine itong trooper diba?
    TS,
    Feb 2006
    #1737
    Quote Originally Posted by vroom888 View Post
    TS,
    TS,
    sir ,
    as per some posts before pwede yan ,
    even Innova, Fortuners , Montero and Santa Fe na mas modern na yun CRDI engine e pwedeng pwede
    just be mindful lang ng Ratio and your ride will be fine
    TS,
    TS,
    sir ,
    #1738
    Thanks,
    but i was just recently reading from previous posts' that 2T FC would build up in the nozzles thereby pluggin' them. any truth on this?
    Thanks,
    Jun 2011
    #1739
    Ash content of 2t oil is even lower thAn the ash content of diesel...
    #1740
    do i need to change fuel filter?
Diesel owners that add 2T oil to fuel
