Page 37 of 48 FirstFirst ... 2733343536373839404147 ... LastLast
Results 721 to 740 of 1853
    Not sure if this has been discussed before, but I'm curious - if adding 2T is so beneficial to most diesel engines in the country, why hasn't it been added yet as an additive by the fuel companies?
    Kumbaga, same with the Khaos supercharger and other miracle products, if they're so good how come the big companies aren't clamoring over it?
    Posted via Tsikot Mobile App
    Apr 2011
    ^ a lot.
    - siret
    Jul 2011
    modern diesel engines, with crdi high rail pressure. The need for ULSD - ultra low sulfur diesel for these engines is a must.
    high sulfur will foul the fuel metering.
    high sulfur is detrimental to the life of injectors, cat con, dpf. thats why some car companies were hesitant to introduce their euro IV compliant diesels. aside from dirty diesels here.
    to meet the environmental restrictions.
    2% biodiesel as shown in page 1 of this thread is beneficial to diesel engines as for lubricating properties.
    old school diesel were designed before LSD low sulfur diesel. if im not mistaken. so adding 2T is awesome.
    So how come Montero/Strada/Everest/Ranger/Fortuner/Hilux owners are claiming improvements from adding 2T? These are all CRDi vehicles..
    Regarding the detrimental effect, how long exactly before these manifest? I've heard that some CRDi users have been adding 2T for years with no problems..
    It was posted here before that there is a max rail pressure which will suit using 2t oil on CRDi's. Kaya BMW, Merc, Audi etc (high-end euro cars) must not use 2t oil. Dvldoc has a good explanation on these afaik in the first few pages.
    Apr 2012
    afaik, jaso FB rating ang recommended na gamitin kasi mineral based siya. higher ratings are either synthetic na or mataas na ang ash content.
    Aug 2008
    Quote Originally Posted by chris143135 View Post
    I've read almost everything here from page 1, though I just want to ask something regarding my situation I've been using 2t for a month already (minimum of 1k gas refill unfortunately no full tanks since im still testing 2t) and I'm not showing any signs of clogged fuel filter. All results are positive so far. I've read that it is recommended to change the fuel filter after using 2t, my question is do i still need to replace mine even though im not showing any signs of clogged filter? Normally, based on your experience after you started using 2t how long would it take for it to clean the entire fuel lines and injectors? Thanks in advance!
    It is recommended that you change fuel filter after using 2t. Dirt in the fuel lines and fuel tank become loose when you add 2t and might end up in the filter or worse might escape and goes to the injectors. It is safer to have a new filter, imo. But if you are due for an oil change very soon, then it might be more practical to change the fuel filter then.
    Jul 2010
    Mga Gurus, so what FC 2T non synthetic oil "brands" are the best to use for our diesel cars since FC is low ash & has a cleanest burning for diesel fuel?
    Jul 2011
    mas mababa ash content ng JASO FC afaik, ang di lang rekomendado ni doc yung pagiging synthetic nito at sa opinyon nya maaaring mag-iwan ito sa mga injectors o nozzles. sa ibang forum anumang pinaka cheap na mineral based 2T ang mainam. advantage lang ng FC ay low ash formulation nito.
    May 2010
    Mga sir, okay ba ang 2T sa Focus TDCi?
    Jul 2013
    sir mam ito po na pansin ko gumagamit me ng 2t sa adventure namin na pang biyahe shell po at sa sea oil me nag kakarga napansin ko po sa adventure namin may itim na usok den maitim na cabon sa dulo ng pipe pano po kaya ito need ko pa ba ituloy or stop na may nag advice sakin na pa lagyan ko ng tubo yong tambutso ko near sa engine para daw malinisan need advice
    Quote Originally Posted by homework View Post
    Unang Caraga lang? Natanggal lang yung carbon deposits sa makina mo. Try 3-4 full tank dapat mawala rin yan.
    Sent from my GT-I9100 using Tapatalk
    May 2009
    Quote Originally Posted by edtf View Post
    Nangyari din sakin yan the first few tankloads ko.....from black to gray ang smoke nun. tinuloy tuloy ko lang then nagclear na sya. could be the 2t doing the initial decarbonization.
    check mo rin filter malamang malilinis din ang fuel tank tsaka fuel lines.
    Baballik na uli ako sa Shell V-Power Nitro plus Diesel at Shell 2T. Sinubukan ko ang Petron diesel max at 2T nila, observe ko lang mas mausok at mas makalog ang makina, parang yung time na wala pang 2T additives ang pajero ko.
    Pwede bang 400mL agad ikarga ko na 2T pag nagpafulltank ako uli ng Shell V power Nitro?
    Apr 2014
    Just wanna try this 2t added into diesel thing,how about on my l300 2011 model with 4d56 engine but not crdi and usually i full the tank bout every 2 weeks; 45liters,how many ml of 2t should i add?
    Jul 2006
    Quote Originally Posted by coolasky View Post
    5ml per 1 liter of fuel is what the common measurements if you back read so you can try po for 45 liters at 225 ml.
    nasa inyo po yan kung babawasan nyo or dagdagan pa.
    normally saken mas mababa sa 5ml/1liter yung sukat ko, nilalagay ko lang 160 to 180 ml lang in 45 liters saken
    Apr 2012
    10L = 50ml or 2oz 2t
    20L = 100ml or 3oz 2t
    30L = 150ml or 5oz 2t
    40L = 200ml or 7oz 2t
    50L = 250ml or 8oz 2t
    60L = 300ml or 10oz 2t
    70L = 350ml or 12oz 2t
    80L = 400ml or 14oz 2t
    90L = 450ml or 15oz 2t
    100L = 500ml or 17oz 2t
    *add 2t before filling the tank
    Apr 2014
    Tnx a lot,ill try it on my next full tank.
    Apr 2014
    But how will i know how many ml of 2t should i fill if i dont know yet d liters of my full tank.
    Jul 2010
    Does'nt need to be accurate, estimate it using your fuel gauge in your panel say * 1/4 tank remaining you will fill around 60 lit to full the tank (observe it) so you need 300ml of 2T.
Diesel owners that add 2T oil to fuel
