Page 83 of 93 FirstFirst ... 3373798081828384858687 ... LastLast
Results 1,641 to 1,660 of 1853
    #1641
    Quote Originally Posted by birman View Post
    Mga sir i still have a little less than half tank of diesel which i added a small bot of petron powerburn 2T when i gassed up to half tank. On tuesday i myt do a long drive so m planning to gas up another 1k worth of diesel. Is it ok to add another bot or 2 of powerburn 2T? F so, wat wud u suggest? 1 or 2 small bot? TIA
    Kung ako, Pag nagpa-full tank nalang ako tsaka ako maglalagay ng 2T. To be safe, 1 bote lang pwede na
    #1642
    Double post!!!!!!!!!!!
    Dear admin, bakit ganito? Palagi nalang double post in one click/submit?
    Apr 2014
    #1643
    Eto para sa nahihirapan sa computation. 40L Diesel add 200ml 2T oil.
    #1644
    yes, the same thing I did when I first added 2T for my rig. I had the tank full (correct me if wrong but the full tank of FM is somewhere 90 liters) and added 2 bottles of 2T oil instead of one bottle only.
    Nov 2004
    #1645
    Ako dko na sakto, bsta 2k dieselmax palagay isang boteng maliit na petron powerburn 2t.
    Nov 2004
    #1646
    Eiko brand japan glow/heater plugs garantisado ko na mag 2yrs na ok pa din, vs pm165 wala pa 1yr kaput na. Sa motorix ko nagpakabit ng Eiko orig japan ka presyo lng dn nmn ng pm165 mura lng
    #1647
    recently i stopped using 2T. Bioaktiv biodiesel na nilalagay ko. mas smooth parin pag biodiesel gamitin. even at less than 1% na mix maganda na result. kaya napapaisip ako kung may biodiesel ba na mix yung diesel natin.
    Dati sa strada yan din gamit ko, kaso biglang hindi na nag-cacarry yung nag-iisang tindahan dito. Kaya 2t oil na lang. I wondered too kung bakit parang kulang ata biodiesel mix na binebenta sa atin.
    Na-try ko din Petron turbo additive, mas okay pa din yang biodiesel mix or 2t.
    #1649
    out of stock na nga daw yung bioactiv sa source ko. 3rd week Feb pa magkakaroon ng stocks. sobrang smooth talaga with bioactiv.
    #1650
    Feb 2014
    #1651
    sabi di daw maganda effect ng biodiesel sa mga seals pag sobra sa 5% ang content sa diesel natin.
    Jun 2011
    #1652
    yung biodiesel mix hindi ata compatible yan sa CRDI engines....
    may friend ako nagpa karga sa biodiesel.. tumirik ang culprit yung fuel...
    Jun 2011
    #1653
    Could be, pero dapat sa lahat nag CRDi mangyari yan. kaso parang wala naman ako nababalitaan na negative effect nang biodiesel. Ang kaso pa, kunti nga lang ata gumagamit. hehe
    Jul 2013
    #1655
    Quote Originally Posted by chris143135 View Post
    Wag ka mag-alala. Sa ilalim ng batas, maximum 2% lang ang required biodiesel mix.
    #1656
    dapat walang problem ang biodiesel sa crdi. sa europe kasi puros crdi na mga sasakyan and and if im not mistaken, required din biodiesel sa fuel nila.
    baka dirty fuel yung cause ng problem sa friend mo?
    Apr 2014
    #1657
    dami kasi smuggled fuel nagkalat sa mercado.
    May 2010
    #1658
    Noobie question:
    Do you still add 2t on VPower?
    Thanks.
    Apr 2010
    #1659
    Quote Originally Posted by romeocharlie View Post
    Noobie question:
    Thanks.
    I would still add it, sa akin yung Petron Turbo Diesel nilalagyan ko pa rin.
    Mga 4 months akong nag stop maglagay ng 2T, naiingayan ako on startup. Last full tank sinubukan ko ulit, noticeable improvement agad the next day
    Noobie question:
    Thanks.
    #1660
    nangangati na ang kamay kong lagyan ng 2T ang 1yr old D4D VNT ko.
Diesel owners that add 2T oil to fuel
