Page 40 of 93 FirstFirst ... 303637383940414243445090 ... LastLast
Results 781 to 800 of 1853
    Nov 2004
    #781
    Baka clogged injectors or fuel filter na? 2t will also clean your fuel lines e. In my fieldmaster, wala naman ganun.
    Naku paps ganun ba? After 15secs apak all normal na naman. Baka yung mga nalinis sa fuel line napunta sa injectors? Bagong palit na kasi ko ng fuel filter orig pa nga di ko pa alam nun bosch sa binondo.
    Pero may nabasa din kasi ko dito na ganyan symptoms nung nagkarga ng diesel na contaminated ata or low quality bumaba idling on cold starts, dinrain lang nya tank then karga petron turbo diesel yun ang loyal brand nya before magkarga ng low quality diesel, after that ok na.
    #782
    Quote Originally Posted by halimaw View Post
    personal opinion ko, useless ang turbo diesel sa FM natin. cause old school diesel engine tayo. try loading up with seaoil/unioil + 2t
    Jun 2011
    #783
    Sana po may makatulong...
    Pajero FM 4m40
    Is it normal after adding 2T my idling at cold starts becomes very low that causes the car to vibrate a lot so what I do is step on the accelerator for around 15secs after that the idling already becomes normal. I dont experience this before when I still wasnt adding 2T. Thanks.
    This is the only problem I experienced with 2T, all are positive effects. Smoother engine performance, less vibration, more power, lesser diesel consumption, etc.
    sir ganun din sakin bumaba idling ng kunti... kaya itinaas ko nalang ulit....
    Jun 2011
    #784
    Pajero FM 4m40
    May 2012
    #785
    There is a new product released by Liqui Moly.
    LIQUI MOLY - Motor Oils, Additives, Car Care - Additive for blockages
    "The additive is added before fuelling every 2,000 kilometres. The contents of a 250 ml can is enough for 50 to 70 litres of diesel fuel and is suitable for all vehicles with a diesel particulate filter, as long as they don't have an electronically controlled additive tank system for filter regeneration, as is the case in Citroen and Peugeot vehicles."
    Was wondering, since I am already adding 2T oil in my Montero, will this also help in keeping the diesel system clean? Or not necessary if I use 2T every fill-up?
    Quote Originally Posted by Arj_11 View Post
    May DPF ba montero? How much ba yan?
    Adding 2 stroke oil to diesel tank - read this - The Brick-yard - Page 1
    Compute whichever is cheaper and use it.
    #787
    Mga Sirs, just back read this thread and I've decided to put 2T oil in our 2009 Grand Starex CRDI para kasing wala masyadong Hyundai vehicles na naglalagay ng 2T, ok lang ba ito? Am also planning to put it in our month Strada VGT and Pajero BK, kahit bago pa lang ok lang kaya ito? TIA
    May 2009
    #788
    IIRC, dvldoc or someone mentioned a decrease in idle rpm. sakin di ko mahalata tsaka wala man tachometer yung sakin. i'll gonna try also next time yung liqui moly diesel purge na nabasa ko sa chedeng forums.
    Nov 2004
    #789
    Thanks mga ser.
    Parang alam ko na culprit sa low idling pag bagong start, naisipan ko lagay sa voltmeter option yung turbo timer, nasa 11v+ lang reading pag off pa makina dapat daw 12.65v+(engine off) pag new batt, inobserve ko pag start ng makina low idle sya mapalag from 11v unti unti umaakyat pag dating sa 12v+ tumataas na idling hanggang sa umabot na ng 13.8v-around 14v. Pag tunog din nung 3rd click sound sa glowplugs off ata yun nakakatulong din tumaas idling.
    Habang di pa nakakapagpalit ng batt tapak muna konte(.9k rpm) silinyador for around 15secs para wala palag di maapektuhan supports.
    Jun 2011
    #790
    Quote Originally Posted by lexwen View Post
    parang nabasa ko dati dito hindi po na kailangan NG 2t sa grand starex....
    sa strada at pajero maganda cya... pero sa GRAND STAREX HINDI na daw po advisable mag lagay at mataas na daw ang pressure ng injection pump ng starex...
    Apr 2009
    #791
    I've been using 2t Oil for about 10 months on my 2001 Isuzu Hi-Lander Xtrm 4JA1 N/A. Natuwa ako sa Result ng Emission ko nung nagpa rehistro ako last April. I got 0.16 sa Emission Result w/ 2t Oil + Linis Pipe. Halos kasabayan ko lang yung Owner Type na Gas Fed which is nakakuha ng 0.30 sa Emission Result. Sobrang tuwa ko dahil mas mababa yung nakuha kong Emission Result.. Biruin mo Gas vs. Diesel hahahahaha.. Halos hindi makapaniwala yung ahente sa Emission Center sa LTO..
    Apr 2010
    #792
    Catch can is a must on old school diesels.
    Hello po.......i just want to ask RE: catch oil...where is this catch oil should be connected...which part of the engine...i understand there is an input and output(don't know the term) in this catch oil....Thanks in advance...God bless...
    #793
    Quote Originally Posted by ben1031 View Post
    try to locate a hose that connects from the cylinder head(cover) to the air intake. connect the oil catch can there. connection should be: cylinder head --- oil catch can --- air intake.
    Apr 2010
    #794
    Quote Originally Posted by limarj View Post
    Salamat ng marami sir limarj..i forgot to mention my ride..Mine is isuzu hilander xtrm 2000...parehas lang po ba ang connection sa engine ko...salamat po ulit....
    Aug 2008
    #795
    Yup parehas lang yan. Try googling it, i think may mga pictures naman to illustrate.
    Apr 2008
    #796
    Good day! Will 2T work sa alterra ucx (2013) nakita ko ksi na nagamit na ito sa alterra pero unsure ako kun pareho lng b engine nung nakatry ng alterra sa 2013 na UCX.last question po eh kung gumagamit ba ako ng biodiesel eh same parin ba ung ratio na ilalagay ko sa 2T?
    Apr 2009
    #797
    good day!
    based on the info i've read on this thread, i started adding 2T oil to our 2003 mitsubishi adventure SS. i always gas up caltex diesel due to convenience, so i tried adding Havoline 2T to our ride. here are my initial observations:
    1. no difference in pulling power or response (after 2 full tanks)
    2. dark smoke was obvious when pressing hard on the accelerator during overtaking.
    3. shut off shudder was "somehow" lessened.
    4. engine noise at idle remains the same.
    5. idle speed remains the same.
    6. FC remains the same.
    practically no difference was felt using 2T oil.
    then i switched to Petron diesel max, and was surprised to the following:
    1. engine sound at idle was a "little" bit quieter.
    2. throttle response was greatly improved, as well as acceleration.
    3. shut off shudder was lessened further.
    4. smoke was visibly reduced to almost nil even on overtaking situations.
    i'm still observing the new mix of petron diesel max / havoline 2T. but i'm quite impressed by the initial response. i'm scheduled to have my timing belt replaced, and hopefully, the engine will run even quieter after replacing the belt and balancer bearings.
    for now, i'll be continuing using this mix on our ride. thanks for the info guys.
    #798
    Quote Originally Posted by garfield_08 View Post
    good day!
    also remember to replace your air filter
    Apr 2009
    #799
    will do sir! thanks.
    isabay ko na rin linis ng injectors plus replace fuel filter for better results.
    May 2008
    #800
    Quote Originally Posted by MR_MAHAROT View Post
    I use it in our 2009 Alterra and its running smooth! definitely noticeable changes. I don't think isuzu has changed the engine of the Alterra puro kabit lang ng mga accessories Don't forget to use the recommended ratio. Minsan napadami lagay ko parang nawalan ng power.
Diesel owners that add 2T oil to fuel
