Page 43 of 48 FirstFirst ... 33394041424344454647 ... LastLast
Results 841 to 860 of 1853
    Feb 2014
    sabi di daw maganda effect ng biodiesel sa mga seals pag sobra sa 5% ang content sa diesel natin.
    May 2010
    Noobie question:
    Do you still add 2t on VPower?
    Thanks.
    Apr 2010
    Quote Originally Posted by romeocharlie View Post
    Noobie question:
    Thanks.
    I would still add it, sa akin yung Petron Turbo Diesel nilalagyan ko pa rin.
    Mga 4 months akong nag stop maglagay ng 2T, naiingayan ako on startup. Last full tank sinubukan ko ulit, noticeable improvement agad the next day
    Noobie question:
    Thanks.
    nangangati na ang kamay kong lagyan ng 2T ang 1yr old D4D VNT ko.
    Apr 2014
    Quote Originally Posted by benchman View Post
    Take the plunge. You'll love the results.
    Jun 2008
    My monty and frontier very satisfied me sa performance using 2t oil...
    I've put 200ml+ castrol activ 2t with seaoil exceed diesel (fulltank) on our '08 isuzu sportivo. 23km so far, di ko pa ramdam yung quieter engine sound. Yung exhaust smoke naman mejo nawala while running. Pero pag ni-rev ko at stand still maitim ang usok. I don't know kung ganun talaga or i still have to wait for the effects to kick in.
    Any tips will be appreciated. Thanks!
    Quote Originally Posted by birdiego View Post
    i don't know how many liters to fill your sportivo to make it full tank, but from what I understand through my back reading here you need 200 ml of 2T oil per 40 liters of diesel.
    May 2009
    tuloy mo lang. kung hindi man magbago andar e sa PM emission (opacity) mo makikita results. aside from this thread here in PH, foreign threads claim na prolonged lifespan (lower wear and tear) ang mga injection pump lalo na ang nozzles.
    wag mo ring kalimutan magpalit ng fuel filter after many kms, say 1000km? 2000km? etc....your choice. due to the cleaning powers ng 2T e hahagurin ang mga dumi magmula fuel tank down to the fuel lines.
    take note sa mga naka late version crdi (higher pressures than the earlier gen crdi), afaik hindi advisable ang 2T (as per dvldoc). tama ba ako?
    Thanks! I'll keep you posted if i felt the improvements. Sana mawala yung black smoke when revving at full stop. I'm also planning to use this on our elf trucks (eagle and 4BC2) kung maging maganda ang results.
    Questions:
    1 beses lang naman nagpapalit ng fuel filter after using 2t diba?
    Does the exhaust scent depends on which 2t brand used? Inaamoy ko kanina ung exhaust pero amoy usok ng jeep parin.
    Thanks in advance!
    Aug 2008
    Questions:
    Thanks in advance!
    1. You still have to change fuel filters on the recommended intervals.
    2. Yes, per experience. After using caltex 2t, the smoke coming from my exhaust had some sort of bubble gum smell. But you must have the correct ratio.
    using it on old school diesel engines will result in some improvement in engine noise, vibration and emission as per my experience. But don't take my word for it. Try it and give us feedback...
    Oct 2014
    Any experience in using 2t in Mitsubishi Montero?
    Quote Originally Posted by rac98 View Post
    Sorry... What i meant was besides the recommended change intervals of the fuel filter, do i have to change it everytime i put 2t or 1x lang? Then after that, yung recommended change interval na. Thanks!
    May 2009
    siguro closer intervals on the 2nd and/or 3rd replacement (with respect to the 1st filter change) if using 2T regularly lalu na kung yung light duty filters ang gamit mo (use bosch filters as a minimum). pwedeng pwede sa nakagawian mong interval (or even longer) on heavy duty filters (baldwin, fleetguard, donaldson, etc.).
    sa akin kasi, bosch ang gamit ko na fuel filter. 1x a year ko sya pinapalitan. 15k kms or less in a year ang takbo ng kabayo ko.
    hindi na cost effective kung palit ka ng filter everytime na magfillup ka ng 2T.
    for your reference.
    Aug 2008
    Sorry... What i meant was besides the recommended change intervals of the fuel filter, do i have to change it everytime i put 2t oor 1x lang? Then after that, yung recommended change interval na. Thanks!
    You do not have to change the fuel filter everytime you put 2t.
    Mixing 2t has no relevance on how frequent you should change fuel filter. 2t mixes well with diesel, it doesn't change the density or thickens viscosity-enough to plug the filter element or obstruct fuel flow.
    Oct 2009
    Hirap na ako makakita ng 2T, puro 4T na.. saan kayo usually bumibili?
    Quote Originally Posted by dobermann100 View Post
    try petron station for powerburn 2t or for any other at Ace Hardware
    Feb 2006
    you can try checking those motorcycle repair shops
    sureball meron nyan , dyan ako bumibili e
    Jan 2014
    Shell gas station madami 2T
Diesel owners that add 2T oil to fuel
